H5ICAT - What Am I Missing - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 12:15 PM   #1
DIYer
jpsmith's Avatar
H5ICAT - what am I missing
Last night I installed an H5ICAT can light, but am dumbfounded about how to attach the light socket to the can housing. The socket was packed into the can with some cardboard, as can be seen in this picture:
After taking the cardboard out, I have no idea what to attach the socket to. Am I missing a piece? Seems there should be something spanning the can for the socket to snap into, but there isn't. I'll snap a pic of what I have this evening, if that helps.
Thanks!
-Jack
jpsmith is offline   Reply With Quote
Old 06-30-2011, 12:22 PM   #2
Master Electrician
Rewards Points: 3,870
The socket is inserted into the trim socket hole and the trim slides into the housing using the attached torsion springs that slide into the brackets where the cardboard is.
brric is offline   Reply With Quote
Old 06-30-2011, 12:24 PM   #3
DIYer
jpsmith's Avatar
Ah, so you need a trim piece with the H5I? It's the only 5" one I used; all my others were H7ICAT, which has the socket affixed to the can.
-Jack
Old 06-30-2011, 12:25 PM   #4
Master Electrician
That is correct.
Old 06-30-2011, 12:26 PM   #5
DIYer
jpsmith's Avatar
Well that explains it. Thanks!
-Jack
Goodman CK36-1T a/c that's missing a piece!! 1horsefarm HVAC 10 05-31-2011 09:59 AM
What am I missing? (pic) overland04 Plumbing 1 03-18-2011 12:52 AM
Repairing missing grout in shower stall CLM Tiling, ceramics, marble 14 10-03-2010 10:08 PM
missing bricks on the outside of my house above the front porch roof aredmond Building & Construction 1 10-02-2010 07:34 AM
Goodman Air Handler with Missing Parts cougarhsv HVAC 2 01-17-2007 08:14 PM
