Old 11-06-2009, 10:33 AM   #1
Default H.O. Lighting
Is it true that HO lights will come on bright even in cold conditions?
Barry2080 is offline   Reply With Quote
Old 11-06-2009, 11:41 AM   #2
nap
You talking to me?
nap's Avatar
HO like in High output and if so, I am presuming you are speaking of fluorescent lamps?
HO lamps will start in colder weather than non-HO lamps. There are also VHO as well that will start in even colder weather.
using electronic ballasts also helps lamps to operate in colder weather. A normal lamp using an electronic ballast will often start in weather nearly as cold as an HO magnetic ballast.
just be aware; you need to use HO ballasts with HO lamps, regular ballasts with regular lamps and VHO ballasts with VHO lamps. The wattages are different for each type so the ballasts must match the lamps.
so, I guess the answer you seek would depend on what you mean by:
"cold conditions"
nap is online now   Reply With Quote
Old 11-06-2009, 01:52 PM   #3
I live in nw ohio so temps would be as low as 0 F,and I am talking about Florescent lamps, will they come on bright when it is cold unlike slimline lamps
Old 11-07-2009, 02:38 AM   #4
" Euro " electrician
The true " cold tempture " or " low tempture " bulbs are rated low as -20°F so you can able lit them up that cold the slimline can barely start that cold espcally if hit zero F
For cold weather useage or unheated area do not use the reduced wattage flourscent bulbs they are not worth a crap in the cold they will go dim very fast when it get colder than 40 or so degress F
The 8 foot HO bulbs is 110 watt that is correct bulb for unheated / cold weather useage.
With electronic ballast it may be little more lower starting tempture however if you use standard HO ballast make sure you keep a little spaceing between the luminaire and ceiling to prevent ballast get overheat plus they will make a buzzing noise unless you get electronic ballast verison then it will be quiet.
Merci.
Marc
Old 11-07-2009, 03:34 PM   #5
Electrical Contractor
kbsparky's Avatar
In cold ambient temps, it will take a few minutes for the HO bulbs to obtain full brightness. Be sure that you use the HO-0 bulbs in any case.
-KB
Old 11-07-2009, 06:02 PM   #6
nap
You talking to me?
nap's Avatar
HO-0 bulbs?
Old 11-08-2009, 02:35 AM   #7
Originally Posted by nap View Post
HO-0 bulbs?
High Output - Outdoor verison
that one way they make that verison and it will come in either jacketed or nonjacketed verison.
Merci.
Marc
Old 11-08-2009, 08:26 AM   #8
kbsparky's Avatar
Yes, Outdoor rated. Full 110 watt output as well.
-KB
Old 11-08-2009, 03:11 PM   #9
nap
You talking to me?
nap's Avatar
are you sure you guys don't mean CW rated?
I have never seen one rated as "outdoor".
Old 11-08-2009, 04:53 PM   #10
Extreme DIY Homeowner
Scuba_Dave's Avatar
I just googled it & there are HO-O bulbs listed as outdoor
They were some also listed as HO-O & CW
So it may mean the same thing ?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Scuba_Dave is online now   Reply With Quote
Old 11-08-2009, 08:18 PM   #11
Yes Dave it the same thing it all depending on the manufacter give the deststion of lettering or number but function wise both are complety interchangeable.
As long you have 800 MA { HO } ballast if you have 1500 MA ballast then it called VHO { very high output } that is diffrent beast the major gotcha between the two both bulbs have same socket so you really have to watch little closer when you replace it.
Merci,Marc
Old 11-08-2009, 09:09 PM   #12
nap
You talking to me?
nap's Avatar
I guess I could have googled it as well. I had never seen a lamp designated with an O. I guess I am going to have to research this a bit. I did google it and I came up with an CW/HO-O
Manufacturer: Philips
Manufacturer's Part #: 381764
F96T12/CW/HO-O/ALTO
Color Temperature: 4100K
Life Hours: 12,000
Initial Lumens: 8800
Color Rendering Index (CRI): 62
Base Type: Recessed Double Contact
Don't know why they would apply a redundant marking. I would think there is something about an O that is different than a non-O lamp.
Tags
cold weather lights, ho lighting
More On This Topic
On behalf of Expert Village my name is Bob Lanning. I'm here to tell you about making a train diorama in HO scale. This is an overview of the Clement's house militer, which is actually, had thirteen miles of track in it. We represented track into the... Read More »
Early fall is a great time to begin preparing your garden and plants for winter and next spring. Bulbs should be dug up and moved or stored until spring. You need to know how to properly dig up bulbs in the fall in order to protect the plant. Read More »
How to Laugh like Santa
How to Laugh like Santa by Expert Village
On behalf of Expert Village I'm Santa Claus. Actually I'm Pat Louis and today I'm going to teach you to become a professional Santa Claus. Now Santa of course has to speak. Now the main thing here is to remember that you walk in and see a bunch of kids... Read More »
Hi this is Yolanda Vanveen on behalf of Expert Village. Cyrthanthus Mackenii is a beautiful flower from that blooms every summer from South Africa. It grows on the mountainside and it is a beautiful plant in the iris family kind of like a crocosmia that... Read More »
Hi I'm Amanda on behalf of Expert Village. In this clip I will be chopping the garlic. The herb cucumber, yogurt calls for 1 clove or garlic minced and the falafel calls for 2 cloves of garlic halves. So I'm going to remove the bulbs here from the garlic... Read More »
DIY Lighting Fixture stubits Electrical 11 10-13-2009 03:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 02:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 02:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 10:06 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
