Old 09-08-2011, 12:47 PM   #1
Guy--Generator to main hook up
Hello everyone:
This is George from Michigan, I have a general question regarding the installation of a Wind Turbin. Does the NEC code require that a Master Electrician License is necessary to connect to a main service entrance?
George Groat is offline   Reply With Quote
Old 09-08-2011, 01:10 PM   #2
DIY Hack
Mr Chips's Avatar
If you can edit your title ( and move it to electical forum) you'd probably get an answer from someone who actually knows, but I'll give it my best guess if that's any help:
There is probably nothing in the NEC that requires this, but you will need to pull a permit for sure, and the local code may require it. Your permit office would be the place to start.
Like I said, just a guess, so take it for what it's worth. If you can edit your title to be more specif to your question, that would attract members who probably forgot more about the NEC than I'll ever know
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-09-2011, 07:36 AM   #3
Many areas allow the live in homeonwer to do their own electrical work. You still have to follow local code, get permits, etc.
Old 09-09-2011, 07:47 AM   #4
Super Moderator
Welcome George---I modified the title and moved this to electrical.
My guess is YES--Call your power company---Most require that the generator can not back feed the powerlines and kill a lineman---so I bet they want that part of the job done by a licensed electrician.
Just a guess.----Post your location --that will get you local code info.---Mike---
Old 09-09-2011, 07:49 AM   #5
Code05's Avatar
Pretty much what they said. The NEC/IRC/IBC does not dictate who can do electrical work, that is a jurisdictional issue, it dictates how the electrical work is to be done.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Speedy Petey (09-09-2011)
Old 09-09-2011, 07:51 AM   #6
Code05's Avatar
OP said Michigan.
oh'mike (09-09-2011)
Old 09-09-2011, 12:16 PM   #7
You might have a bigger problem. Because residential wind turbines are still quite rare, people have trouble getting a permit to install one because their jurisdictions don't know what codes might apply.
Main Circuit Breaker Question vladmir1111 Electrical 2 08-20-2011 09:15 PM
main lug or main breaker kenmore Electrical 14 06-18-2011 12:13 PM
DWV remodel. Can I do this with my main? antalamo Plumbing 0 03-19-2011 10:29 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 09:18 PM
