GU 10 Halogen Can Light Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-10-2008, 06:49 PM   #1
My builder put in about 20 small directional can lights with GU 10 Halogen bulbs. They are now starting to go out.
The trim on these has a diameter of 3 and 3/4 inches. There is an outer ring, and an inner ring that the bulb rests in. The inner ring swivels.
There is no way to get the bulb out without taking the entire assembly down out of the can. I have read that you are supposed to twist and then pull the bulb out, but that does not work with this fixture as the bulb diameter is larger than the inner ring.
So the only way the bulb comes out is when you take the entire assembly out and take the bulb out the top of the assembly. So, why not just take the assembly out, replace the bulb and get on with it? Because once the assembly comes out, it will not go back in the can without slipping right back out. There are several small clips affixed to the inside sides of the can, and that appears to be all that was holding the assembly in place. But once the assembly is removed once, these clips will no longer hold it in place. If you try to bend the clips a bit for more pressure, they break.
Any ideas???
cbiss is offline   Reply With Quote
Old 12-10-2008, 07:50 PM   #2
dSilanskas's Avatar
Any ideas???
You should post a pic. Or do you know what model of the recess light it is?
dSilanskas is offline   Reply With Quote
Old 12-10-2008, 08:16 PM   #3
Photos posted in My Photos
Good idea - see My Photos
Old 12-10-2008, 08:52 PM   #4
If they didn't last their rated lifetime you may want to reduce the voltage to them.
Hall light worked before installing a new light fixture in bathroom jcfan7 Electrical 40 02-23-2008 10:46 AM
Wall outlets stay charged even when light switch is turned off proofer Electrical 33 01-25-2008 05:43 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 09:53 PM
Halogen flood lights chicagonyc Electrical 5 07-15-2006 11:11 PM
