Grrrr Smoke Detectors Not Compatible?? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 09:11 PM   #1
Renovating My Land Yacht
Rewards Points: 616
Grrrr Smoke detectors not compatible??
This is for the house up north. Built in 03.
Went to replace a smoke detector today and bought a Kidde Firex hard wired detector. Came with a wiring harness with black red and white wires. Pulled the old one and it was black yellow and white.
Called Kidde and apparently when they bought out Firex they changed the wiring and I was told that they will never be compatible. They are telling me I would have to replace 16 hard wired smoke detectors including the wiring. Anyone else dealt with this?
I know that I can put in a battery only one but being as the house is being rented I would prefer the hard wired ones in case the batteries are not changed.
What are my options (if any)
Robyn
forcedreno2012 is offline   Reply With Quote
Old 06-08-2013, 09:23 PM   #2
Resi EC
Rewards Points: 252
16 hard wired SD?
better read the paper work with it, make sure you can have that many
pretty sure the cut off is 12
Gac66610 is offline   Reply With Quote
Old 06-08-2013, 10:44 PM   #3
Rewards Points: 734
Replace them all, it's been 10 years.
The NFPA recommends that they all be changed after 10 years.
Depending upon what model you can interconnect up to 24 devices, 18 of which can initiate.
AandPDan is offline   Reply With Quote
Old 06-08-2013, 11:18 PM   #4
Rewards Points: 616
Sorry GAC, probably should have clarified its 16 over 2 houses.
I don't have an issue replacing them but the way the person was talking I have to replace all the wiring as well and not just the harnesses?
Old 06-09-2013, 02:01 AM   #5
Resi EC
Rewards Points: 252
I'm not sure why you would need to replace all the wiring.
The homes were built in 2003, so I would guess that they are interconnected,(red,black,white, in the SD boxes)
just re-read your OP
I'm wondering if they meant the harnesses, not the house wiring
Old 06-09-2013, 05:15 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 820
When you say one of the wires is yellow....is it the 3 wire pigtail on the old smoke detector?
If the yellow wire is one of the wires in your 14/3 NM cable....it's simple....the red wire on the smoke detector pig tail goes to the yellow wire on the nm cable.
What is real important....all of the detectors are the same.
The average life on a smoke is 10 years...on CO detectors, 7 years. In fact, when a CO reaches it's 7 year mark it starts chirping at you....nothing you can do but to replace it
ddawg16 is online now   Reply With Quote
Old 06-09-2013, 08:18 PM   #7
Rewards Points: 616
The yellow is on the existing wiring. I will grab some pics tomorrow so you can see what I am looking at.
Old 06-09-2013, 08:42 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 820
Existing as in the 14/3 that goes into the ceiling?
All that really maters is that you have 3 wires coming out of the ceiling and those 3 wires daisy chain to each smoke....
Black goes to black
White goes to white.
And the red on your new pigtail goes to the 3rd wire (yellow) in the romex.
I have the Kidd's as well....and I know the pigtail your talking about.
Just swap out all of them.....
Old 06-09-2013, 09:54 PM   #9
Licensed electrician
Rewards Points: 1,028
The yellow was just the color used for the interconnect.
Smoke Detectors - Ionization vs. photoelectric ddawg16 General DIY Discussions 3 07-26-2012 01:47 PM
adding new wired smoke detectors to existing wired smoke detectors CapeCod153 Electrical 9 06-21-2012 06:03 AM
Smoke detectors and reaction time Red Squirrel Safety 4 02-23-2012 09:15 PM
Smoke Detectors on Different Circuits Mililani Electrical 13 10-17-2010 07:35 PM
Wiring Smoke Detectors - Has to be straight run? WaldenL Electrical 15 08-30-2009 10:22 AM
