#1 |
Grounds and Neutrals
Hello everyone...Second post and hope you can help..At 65 I'm trying to understand electricity ( Never to old I guess)
I understand that when ac voltage and current are coming in on the ungrounded conductor to the load and returns via the neutral back to the source...What I am confused about is when voltage and current return on the neutral from the source to a sep neutral bar where the equipment grounds are also connected, why isn't there voltage and current on the equipment grounds going back to the load....I know that the neutrul bar is grounded but wouldn't that prevent current getting back to the load also...Thanks in advance and I hope I made myself clear....Tom |
#2 |
Licensed electrician
The current is not trying to get to ground, but back to the source, ie the transformer. This is why neutrals and grounds are bonded in the service panel. This will allow the breaker to trip on a fault.
Earth ground typically has a high resistance.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | bbo (02-27-2013) |
#3 |
Thanks Jim...I understand that current returns to the source from the ungrounded conductor, but doesn't current reverse (alternating current) and come back from the source on the neutral conductor on a 120v circuit where the neutrals and grounds are connected in the sep and back to the load...Thanks
#4 | |
Field Service
Grounds and NeutralsQuote:
#5 | |
| Display Modes | |
| Need to know if my grounds and neutrals are connected right | dorlow | Electrical | 185 | 01-15-2012 03:54 PM |
| Are grounds and neutrals supposed to touch in the breaker box? | tibberous | Electrical | 7 | 08-13-2011 02:06 PM |
| Grounds and Neutrals, What To Do? (pics inside) | ts46176 | Electrical | 13 | 07-24-2011 02:18 PM |
| Double tapped Grounds and neutrals | sarychapina | Electrical | 3 | 06-08-2011 07:35 PM |
| Neutrals and grounds in main panel | steve37887 | Electrical | 6 | 11-12-2009 09:20 AM |
