Grounding Worries... - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2012, 05:36 PM   #1
grounding worries...
my dryer has a white ground wire coming from inside. my cord has a green ground wire, along with the other 3 wires (red white black). what should i do about the 2 ground wires???
Gyallo is offline   Reply With Quote
Old 10-25-2012, 05:58 PM   #2
Licensed electrician
Rewards Points: 1,456
Do you have a 3 or 4 prong receptacle?
Old 10-25-2012, 06:02 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
White is NOT a ground. It is a neutral.
Old 10-25-2012, 06:05 PM   #4
That too.
Old 10-25-2012, 10:13 PM   #5
Rewards Points: 258
along these lines, my new house has a three prong outlet for the dryer, the current plug on newer dryer is a 4 prong, i put it on when we moved into our old house, I cant remeber if the old cord was a three or four prong. so when i get the new cord most likely tomorrow evening, and install some time this weekend. I will put the RED and Black (HOTS) to the thier respective spots and the WHITE (nuetral) to its spot and just leave the Green (ground) alone on the dryer. At least till i get around to rewiring the house. Or am i going to go about it wrong?
redman88 is offline   Reply With Quote
Old 10-25-2012, 10:14 PM   #6
If you need to install the 3 prong cord, you will need to connect the jumper between the neutral and ground on the dryer.
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 09:25 PM
Replacing Light Fixture with No Ground Wire in Home panorama Electrical 42 09-14-2012 09:35 AM
Grounding Switches.... stickboy1375 Electrical 3 08-03-2012 06:59 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
