#16 |
grounding the workpiece you're welding
Nap. I'm not misunderstanding the term. All I'm asking is: does the workpiece or metal table its on need to be grounded separate from the welder's work clamp. And does a metal piece resting on concrete constitute a ground. thanks
#17 | ||
You talking to me?
grounding the workpiece you're weldingQuote:
#18 |
fabrk8r
jarnold, the concrete, or earth, will not constitute a "ground" as far the the welding circuit. You'll need to connect the actual ground clamp the the workpiece, or table.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright |
#19 | |||
You talking to me?
![]() Quote:
#20 | |
You talking to me?
not trying to start an argument but where have you ever seen a welder with a "ground clamp"? the ground connection being referred to in this situation has nothing to do with the machine. |
#21 |
fabrk8r, Yes, I know the work clamp has to be clamped to the workpiece or table. But if you need to separately ground the workpiece for safety, does a workpiece connected to concrete constitute a ground.
#22 |
fabrk8r
nap, I know it seems like it shouldn't matter where the ground clamp is positioned, and for most welding processes it won't, but there is something about the GTAW, or TIG, process that will make the arc deflect under certain circumstances.
I fabricate a lot of stainless steel sinks and countertops and when welding where three surfaces meet it is almost impossible to control the direction of the arc unless the ground is positioned very close to the weld. An added advantage to this is that since there is little distance between the ground and the electrode it makes it less likely that my body will short the circuit and get a shock, which commonly happens in out-of-position welding.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright Last edited by fabrk8r; 09-06-2010 at 01:58 PM. |
#23 |
fabrk8r
nap, every welder I've ever seen has a ground clamp.
I'm sorry, I should have used more appropriate semantics...when I say ground clamp, I mean work clamp...I'm a fabricator, not an English teacher. I apologize for the confusion. I know that all my fellow workers would look at me funny if I said "work clamp".
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright Last edited by fabrk8r; 09-06-2010 at 02:03 PM. Reason: used wrong semantics |
#24 |
fabrk8r
jarnold, there is no need for a separate ground.
#25 | ||
You talking to me?
it sounds like you are speaking of the work lead and I am not disagreeing with your points on that. I understand the process well enough to know what you are speaking of with the arc. Quote:
#26 |
You talking to me?
you are incorrect. Stubbie presented contrasting information from a dependable source.
the fact you and friends are getting shocked proves why you do need an actual ground connection. That would prevent, or at least minimize, the shocks you are experiencing. |
#27 | |
fabrk8r
Here is an example of an electrode holder, or stinger, on the left used for SMAW (shielded metal arc welding, or stick welding) and a common ground clamp on the right. Without either you'll have a hard time making a weld.
#28 | |
You talking to me?
I cannot say I have ever seen a welder with an true ground clamp. (including the one you provided a picture of) . Ground clamp is a commonly used misnomer used to indicate the work clamp. |
#29 | |
UAW SKILLED TRADES
sorry I had to run a few errands but when I returned I read thru my millermatic 225 manual and found this statement
" One nice thing about the NEC articles ... you have lots of choices" Stubbie Last edited by Stubbie; 09-06-2010 at 05:25 PM. |
#30 | ||
You talking to me?
that would support your statement that the grounding must be separate of the work conductors. |
| Display Modes | |
| Grounding of Welding Generators | ktitus | Electrical | 3 | 11-15-2009 09:49 AM |
| welding grounding | Jeff7131 | Electrical | 8 | 11-02-2009 02:38 PM |
| Grounding Method | Steelhead | Electrical | 6 | 02-05-2009 12:06 PM |
| Anyone want to take a shot at why #6 to attach antenna ground to breaker? | Piedmont | Electrical | 44 | 01-08-2008 05:11 PM |
| NEC Question | Jafsvcs | Electrical | 1 | 06-13-2007 06:45 PM |
