Grounding Wire On Roof - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 02:48 PM   #16
Licensed electrician
Rewards Points: 1,242
I am lost as to why they felt the need to bond or ground the WH. Grounding and bonding should have already been in place. If they needed to connect the solar array I would have hoped they could have found a way to connect to the GES.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
gregzoll (10-24-2013), stickboy1375 (10-25-2013)
Old 10-24-2013, 05:38 PM   #17
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Does this go to the water main or along with the water heater to meet code?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 10-24-2013, 06:14 PM   #18
rrolleston's Avatar
If it goes to the water main its required but they should have found a better way of doing it.
Old 10-24-2013, 06:15 PM   #19
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I was under the impression from the OP that he has a service change.
Old 10-24-2013, 06:35 PM   #20
rrolleston's Avatar
Me too. What I would really like to know is what kind of connector is used where that goes through the roof. If I was the OP I would be calling them back and telling them you did not approve the holes in the roof
The Following User Says Thank You to rrolleston For This Useful Post:
plummen (10-25-2013)
Old 10-24-2013, 07:34 PM   #21
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Why didnt they just run it from attic to attic ,then fire caulk the 1/4" hole they would have needed to run it through?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 10-25-2013, 07:09 AM   #22
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Philly Master View Post
So they could jump the hot and cold water lines'.
so just install a jumper between the two, if they are even isolated from each other.... I still see no need to run a bond wire to the water heater, obviously, they have no clue either....
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
mpoulton (10-25-2013), Philly Master (10-25-2013), plummen (10-25-2013)
Tags
electric , ground
Bathroom Fan and no grounding wire majch Electrical 1 09-03-2012 01:55 PM
yet another 3 wire range hookup question - grounding receptacle plate/box? rkg Electrical 7 04-03-2012 02:02 AM
grounding wire marty56 Electrical 9 01-14-2012 12:18 PM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
