#1 |
grounding wire
What wire is this going to meter.Looks as if its a grounding wire since the cable is linked to it also before going in ground.
#2 |
grounding wire
Yes that's the ground.
#3 |
grounding wire
thanks. so i wont need a grounding rod there?
i also noticed no bonding screw in panel ,only a #6 silver rod going to the copper pipe,but its over 25 feet from box.Just trying to confirm proper grounding. ![]()
#4 |
UAW SKILLED TRADES
grounding wire
This may help ..
250.64 Grounding Electrode Conductor Installation. (A) Aluminum Grounding Electrode Conductor. Aluminum grounding electrode conductors cannot be in contact with earth, masonry, or subjected to corrosive conditions. When used outdoors, the termination to the electrode must not be within 18 in. of earth. |
#5 |
grounding wire
What does it say on bonding screw and also grounding the the box ?
#6 |
UAW SKILLED TRADES
grounding wire
If the panel your showing is your 'service equipment' ... ie... the panel that contains the 1st means to disconnect all power from your home then a bonding screw is required. The bonding screw bonds the metal enclosure to the grounded conductor (utility neutral) and by doing so it brings that enclosure to the same potential as all the other 'bonded metal' and also the enclosure becomes part of the effective fault path so a circuit breaker will trip on ground fault.
#7 |
grounding wire |
#8 | |
" Euro " electrician
grounding wireQuote:
That photo you posted that is not legit set up due there are few issue with that one. Merci, Marc
The answer will be based on NEC ( National Electrical code ) or CEC ( Cananda Electrical code ) or ECF ( Electrique Code France ) |
| Display Modes | |
| my Firex hard wire smoke alarms have no grounding | amakarevic | Electrical | 11 | 01-14-2012 09:25 AM |
| convert 3 wire range junction box to receptacle | filby | Electrical | 0 | 06-05-2011 02:33 AM |
| Main grounding electrode wire to panel | rovers1973 | Electrical | 4 | 03-18-2010 07:18 PM |
| romex with thin grounding wire | dogbone | Electrical | 16 | 01-10-2009 09:40 PM |
| Grounding conduit instead of using a ground wire? | stringtheories | Electrical | 10 | 08-02-2008 01:42 PM |
