Grounding Of Welding Generators - Electrical - DIY Chatroom Home Improvement Forum
Closed Thread
Old 11-15-2009, 04:22 AM   #1
Grounding of Welding Generators
Would you please explain the needs of grounding(Earthing) of a Weding Generatos using in an Oil and Gas Plant.
ktitus is offline
Old 11-15-2009, 08:01 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
This is a "DIY Home Improvement Forum". How does oil and gas plant work fit into this???
If you are using one of these things in such a heavy industrial setting I would darn well hope you knew what you were doing before hand.
Are you in the US? I get the feeling no.
Speedy Petey is online now
Old 11-15-2009, 09:47 AM   #3
If the gen. output is V volts, if you don't ground the generator the voltage at either of its leads is indeterminate when measured with respect to ground.
With one lead grounded, the voltage at both leads is predictable; one measures 0v and the other measures V, when measured with respect to ground.
Yoyizit is offline
Old 11-15-2009, 09:49 AM   #4
This site is geared towards residential DIY
Not commercial settings
You need a Pro to go over this installation
OP is from Qatar area - Middle East
Scuba_Dave is offline
Closed Thread
welding grounding Jeff7131 Electrical 8 11-02-2009 02:38 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 12:06 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
