-   -   Grounding of Welding Generators (http://www.diychatroom.com/f18/grounding-welding-generators-57219/)
ktitus 11-15-2009 04:22 AM
Would you please explain the needs of grounding(Earthing) of a Weding Generatos using in an Oil and Gas Plant.
Speedy Petey 11-15-2009 08:01 AM
This is a "DIY Home Improvement Forum". How does oil and gas plant work fit into this???
If you are using one of these things in such a heavy industrial setting I would darn well hope you knew what you were doing before hand.
Are you in the US? I get the feeling no.
Yoyizit 11-15-2009 09:47 AM
If the gen. output is V volts, if you don't ground the generator the voltage at either of its leads is indeterminate when measured with respect to ground.
With one lead grounded, the voltage at both leads is predictable; one measures 0v and the other measures V, when measured with respect to ground.
Scuba_Dave 11-15-2009 09:49 AM
This site is geared towards residential DIY
Not commercial settings
You need a Pro to go over this installation
OP is from Qatar area - Middle East
