Grounding With Water Line Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 03-16-2012, 09:59 AM   #1
Grounding with Water Line Replacement
We need to have a new water line put in from the meter in the parking strip to the house. We've recently had a new electrical panel put in and the electricians pounded two grounding rods into the ground outside our house. Because of this, will the house be just as well grounded if we get plastic pipe as if we get metal?
bubblegummom is offline   Reply With Quote
Old 03-16-2012, 10:44 AM   #2
Rewards Points: 13,712
It's a better ground then what you had and is now up to code.
Old 03-16-2012, 02:08 PM   #3
Great to know! Thanks a lot!
Old 03-16-2012, 03:32 PM   #4
Rewards Points: 1,512
The two ground rods, assuming they were at least 8 feet long, at least 6 feet apart, and driven in almost flush, are good and sufficient for grounding.
The water pipe, if metal, would still have had to have been connected to the breaker panel as if it were a ground rod.
Inline water filter for built-in fridge (water supply line on top) Druidia Appliances 5 03-10-2012 12:05 AM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 10:18 PM
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 09:03 AM
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 06:31 PM
Blockage in kitchen water line. Local Yokel Plumbing 6 03-18-2009 10:34 PM
