Grounding Ungrounded Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2013, 05:57 PM   #1
Rewards Points: 1,062
Grounding ungrounded outlets
People,
Have a few 110v outlets, and only wires feeding them are 2 wire (hot/neutral). House was built in the 40's. I heard one can get grounding if you take a copper wire and connect the green ground screw on outlet to the metal box the receptacle is in. If the receptacle is nailed to wood stud, is this "grounding" of any usefulness at all? If so, how? If not, why?
Thanks!!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 01-06-2013, 06:34 PM   #2
Rewards Points: 6,652
No, incorrect. Only if the wire feeding it is Armored with the bonding strap, or EMT, then you could use the outer sheath as the ground. Other way was running a ground wire to a cold water pipe, that would be bonded to Earth ground.
The Following User Says Thank You to gregzoll For This Useful Post:
noquacks (01-07-2013)
Old 01-06-2013, 06:45 PM   #3
Licensed electrician
Rewards Points: 1,294
You cannot just run to a nearby metal water line. The connection can be in the panel where the circuit originates, or on the GEC if the cable does not have the bond strip.
Old 01-06-2013, 06:50 PM   #4
Code05's Avatar
Rewards Points: 1,104
True, but you could connect to the pipe at the 5' GEC connection.
Code05 is offline   Reply With Quote
Old 01-06-2013, 10:17 PM   #5
I was using the tablet and don't have the cut and paste available. I thought within 5' was an option. Thanks.
Old 01-06-2013, 10:32 PM   #6
Rewards Points: 336
It's not grounded because your studs don't conduct electricity. A functional ground connects the thing that needs to be grounded (in the case your outlet) via a conductive path to something that is the ground (either a wire in the ground or a water pipe). Modern wiring has a ground conductor in it, so an outlet becomes grounded when the electrical path flows outlet > grounding screw > grounding conductor > load center > ground. If you use the jacket of armored cable it can also function as the ground (although I have seen electricians on these boards says that the jacket can rust and become non-conductive over time). Either way there is a metal path from outlet to ground. If you just connect your outlet grounding screw to a wood stud, it doesn't do anything.
JKeefe is offline   Reply With Quote
The Following User Says Thank You to JKeefe For This Useful Post:
Old 01-06-2013, 10:34 PM   #7
If you don't have ground you can change the outlet to a GFI.
Carreiro is offline   Reply With Quote
The Following User Says Thank You to Carreiro For This Useful Post:
Old 01-06-2013, 10:49 PM   #8
joed's Avatar
Rewards Points: 12,026
You can in Canada. I don't know where SE is but if it is in Canada you could ground to the water line.
Old 01-07-2013, 01:55 PM   #9
Thanks, people. I figured that was bogus info, to ground to steel box that is only nailed to wood. Sheesh. Now, whether Im in the SE, or Canada, or Africa, a good ground is a good ground, right?? (house is in S Cal, although, Im in the SE)
Old 01-07-2013, 01:56 PM   #10
Good tip- guess its an option- to change over a bunch of outlets to GFI......better than smashing up plaster walls.....
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
CGFI keeps grounding out. Please help! McCool Electrical 7 07-19-2009 11:55 AM
Grounding an ungrounded exterior circuit Randell Tarin Electrical 16 11-27-2008 07:02 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
