Old 09-01-2009, 08:10 PM   #1
Grounding - Tie-in Question
Hey everyone, I need some help. I have two outlets in my kitchen cabinets that are about 1 foot apart, and one is grounded, one is not. Both outlets have three wires, black, whtie, and green, it's just the voltage checker said the right outlet (Outlet #2) is not grounded. The two outlets are on different circuits (I had to turn off different breakers at the main panel).
So, I'm hoping I can pig-tail in a 14-gauge wire from the grounded Outlet #1 to the Outlet #2, with the new grounding wire hanging between the wall and cabinet.
Will this create proper grounding to the ungrounded outlet, and will it be safe and/or to code? It won't be a problem with the two outlets being on different circuits, correct? The two pictures show what I'm talking about.
Thanks in advance,
Kyle
Grounding - Tie-in Question-elec_1.jpg   Grounding - Tie-in Question-elec_2.jpg
kyletke320 is offline   Reply With Quote
Old 09-01-2009, 08:14 PM   #2
Electrician
I would trace outlet # 2 back and find out where the problem is.
chris75 is offline   Reply With Quote
Old 09-01-2009, 08:17 PM   #3
Insted of cobbling it together, try find out where the problem is.
I would first test it with another tester, not the plug in kind. One lead to black, one lead to ground = 120V
The green wire come from somewhere. Open a few close jboxes,receps,switches on that circuit and find out where it has become disconnected.
Proper is a relative term.
Safe, yeah.
Code compliant, no.
At least attempt to repair it properly.
220/221 is offline   Reply With Quote
Old 09-01-2009, 08:23 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
I'll third the sentiment.
Do it right and find the problem.
Old 09-01-2009, 08:44 PM   #5
I'll see if I can. The house was built in 1958, so I don't know if the wiring was correct when we moved in. Second, we remodeled the kitchen, and had a contractor install the cabinets and move some outlets around, including the two in question. So either he didn't hook something up correctly, something came loose somewhere else, or that circuit was never grounded.
So I guess ultimately what I'm hearing is to get an electrician to check/fix the wiring to do it the right way.
Old 09-01-2009, 08:48 PM   #6
He very likely extended an ungrounded circuit.
Not really.
Stealing a ground from the other recep isn't a deadly sin.
Another option would be to replace the ungrounded recep with a GFCI recep and it will be all good and legal.
4 pin dryer to 3 pin (grounding question)? nadazip Electrical 6 07-06-2009 11:00 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 02:49 PM
