Old 08-12-2010, 06:20 PM   #1
DIYer
Is grounding through armored cable legit for modern code?
I know this was at one time common practice but is it today? Say I wanted to wire an overhead fluorescent light and run hot and neutral inside armored cable and use the armor itself as the ground.
Given that everything is bonded correctly, is it legit to run ground through the metal armor and still meet today's electrical code?
dwoloz is offline   Reply With Quote
Old 08-12-2010, 06:28 PM   #2
Electrician
Proby's Avatar
Yes, you can use BX if you choose, but it's locations are more limited. Where are you planning on using it, in your home?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-12-2010, 06:34 PM   #3
DIYer
This is for my basement/crawl space in my home. The ceiling is unfinished so I wanted to protect the wires
I have 5/16" BX and need to run a hot neutral and switch loop and can only safely stick 3 wires in there so instead of buying new larger BX for 4 wires (3+ground) it would be rather convenient to keep what I have and route the ground through the metal itself
Old 08-12-2010, 06:43 PM   #4
Electrician
Proby's Avatar
BX/AC/Armored Cable is a pre-wired cable assembly.
It seems as if you are talking about using an old piece of BX as Flexible Metallic Conduit (Greenfield).
No, you can't do what you suggest.
Old 08-12-2010, 07:13 PM   #5
Master Electrician
Can someone cite a code article that covers "BX"? Not AC but "BX" please.
brric is offline   Reply With Quote
Old 08-12-2010, 07:25 PM   #6
Electrician
Proby's Avatar
For what reason?
Old 08-12-2010, 07:41 PM   #7
Master Electrician
To show that it is a recognized wiring method under the NEC.
Old 08-12-2010, 07:43 PM   #8
Electrician
Proby's Avatar
You know it's a well known slang term just like the term "romex" (which you also won't find in the NEC, as you know) so why not just speak your mind instead of trying to draw this out...?
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-19-2008 12:03 AM
Which type of Armored cable. helpless handyman Electrical 4 12-01-2007 10:04 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 03:54 PM
Grounding Cable Sammy Electrical 18 04-17-2007 09:16 PM
