Grounding Subpanel Via 10-700(3)(b) - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2010, 09:49 PM   #1
Grounding Subpanel via 10-700(3)(b)
I am wiring my detached garage and am installing a subpanel in the garage fed from my main panel.
I have dug a trench from my house to my garage that is at minimum 24" deep. The trench is about 40' long.
What I am wondering is if I need to install a ground rod, or can I use rule 10-700(3)(b) and simply bury a #4 copper line for at least 20 feet in this trench to achieve proper grounding?
I should note that I am not running my feeder cable in conduit. I am using direct burial with an NMWU cable.
tjames is offline   Reply With Quote
Old 04-18-2010, 09:51 PM   #2
Where are you located ?
I put 2 ground rods out at my shed
If you can't pound them into the ground then laying them in a trench is accepted
Just wire is not code as far as I know
Old 04-18-2010, 11:22 PM   #3
joed's Avatar
Rewards Points: 11,964
If you ran a ground from the house to the garage then I don't believe you need a separate ground rod at your detached garage unless it is used to house animals.
See section 10-208 (b)
Old 04-18-2010, 11:25 PM   #4
Electrician
Rewards Points: 770
I second joed, that is how I have always read the rule on that.
darren is offline   Reply With Quote
Old 04-19-2010, 02:34 PM   #5
Does the ground in the the cable (1 red, 1 black, 1 white and 1 ground) count for this?
Old 04-19-2010, 03:31 PM   #6
Electrician
Rewards Points: 770
Thats how I read the rule, if your getting this inspected(which you are suppose to do) ask the inspector what he wants to see.
Tags
ground rod , grounding , subpanel grounding
Grounding a Subpanel Craigman Electrical 25 12-07-2009 08:25 PM
Adding second grounding bar to subpanel rdy2go Electrical 11 09-13-2009 08:59 PM
Subpanel grounding CAUTIOUSHOMEOWNER Electrical 30 12-02-2008 05:08 PM
Grounding electrode at subpanel Randell Tarin Electrical 18 02-01-2008 10:05 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
