Grounding A Square Box <--newbie Question - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 11:10 AM   #1
Rewards Points: 33
Question
Grounding a Square Box <--newbie question
Hello -
My question is about "grounding".
I have a new house which I'd like to add some more electrical in the garage. I am going to tap into the GFCI that is pictured, add a metal square box on the outside of the wall and run conduit to it's new location. Do I just wirenut the the new and old ground together and/or do I need to run a ground to the metal box?
Thanks.
Grounding a Square Box &lt;--newbie question-electrical-1.jpg   Grounding a Square Box &lt;--newbie question-electrical-2.jpg
dgates12 is online now   Reply With Quote
Old 01-06-2010, 12:03 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
If it is a metal box, it must be bonded.
You can use a plastic box and not have to bond the box.
The cord you have running into the drywall is a violation of code.
Old 01-06-2010, 12:12 PM   #3
Master Electrician
richgriffith's Avatar
yes,you can tap the existing ground and run to new outlets making sure you ground the metal boxes. im assuming your just adding additional outlets to that existing Garage circuit?
richgriffith is offline   Reply With Quote
Old 01-06-2010, 12:35 PM   #4
Rewards Points: 33
...follow up reply
The cord running into the drywall you see is coax cable. The cable company poked a hole thru the wall to mount a signal booster on the outside of the cable box. I assume there should be no code violation to this since a professional did it?
Old 01-06-2010, 12:50 PM   #5
Master Electrician
your good
Old 01-06-2010, 01:06 PM   #6
Rewards Points: 33
Lightbulb
...option #2, new circuit
The other option I have to add Garage power, is to run a new circuit to the panel. I have an open breaker and this totally seems like a do-able option; maybe even better
It seems pretty straight forward to add a circuit, this is what I think the process is....
  1. Turn off power and verify
  2. Cut hole in drywall and attach new Old Work Box
  3. Remove panel cover, turn off breakers, verify power is off
  4. Remove knockout from bottom of Panel
  5. Feed wire from panel to Work Box, secure down wiring
  6. Wire and install new GFCI breaker into panel
  7. Replace panel cover, restore power
Any advice is appreciated!
Old 01-06-2010, 02:12 PM   #7
Master Electrician
go for it! which ever way you decide will work. if it were me i would do the new circuit. that way you got more options down the road. for one your not loading up your garage circuit. two if you decide you need a dedicated circuit for something you got it all ready at your disposal. but either way will work good luck!!
Old 01-06-2010, 02:14 PM   #8
Rewards Points: 33
...thanks!
Thanks Rich, I like option #2 as well.
Old 01-06-2010, 02:19 PM   #9
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
If you are going to do that, why not just mount the box on top and save yourself the trouble of running it up the wall. That is unless you are going to put a receptacle at the box location just below the panel. If that is the case things look good.
Also option 2 is the best thing to do IMHO.
Big N8 is offline   Reply With Quote
Old 01-06-2010, 02:23 PM   #10
Rewards Points: 33
...follow up reply
No, there is not going to be receptacle in the "lower" box, just using this as a junction to tap into. The only reason I would mount it above (but it does make more sense now that you say it), is that I'm nervous with all those wires nearby as you see in the picture.
I'm welcome to any suggestions though.
Old 01-06-2010, 02:27 PM   #11
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Is the wall insulated??
Old 01-06-2010, 02:28 PM   #12
Rewards Points: 33
No insulation, just a plain ol' basic garage.
Old 01-06-2010, 02:34 PM   #13
Chaos Engineer
Big N8's Avatar
Rewards Points: 152
Was there enough room on the right side of the stud cavity at the top by the sill to fit a box? or did you drill holes for the current wire all the way to the stud?
Old 01-06-2010, 02:35 PM   #14
47_47's Avatar
Rewards Points: 62
I'd go with option 2, but run 12-2wg on a 20 amp. Instead of a just a jb with a blank cover, put in a gfci outlet in the metal box.
47_47 is offline   Reply With Quote
Old 01-06-2010, 02:37 PM   #15
Rewards Points: 33
I haven't drilled any holes for anything yet. As far as room goes, the picture shows all the available space before the workers sealed it all up with drywall.
grounding question Skippymartinez Electrical 1 11-30-2009 07:19 AM
Question on QO-20M Square D panel rovers1973 Electrical 6 02-06-2009 08:07 PM
Newbie Solder Question SteveSmith98 Plumbing 9 01-15-2009 09:50 PM
Newbie question about crack in PVC joint LinusInPW Plumbing 8 11-16-2007 11:25 PM
