Grounding Sattelite Equipment - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2011, 09:54 AM   #1
Grounding sattelite equipment
I Need to relocate a satellite powered switch and splitter. It looks like the switch was grounded to a water pipe but the splitter is not.
Does the splitter need to be grounded if the switch already is, (me thinks not)?
It looks like heavy gauge wire, thicker than the 12 gauge I was hoping to use. Is there a requirement for the gauge in this application?
My new location is about five feet from the nearest copper pipe. Is it ok to run the ground this distance?
Drliebs is offline   Reply With Quote
Old 08-21-2011, 10:01 AM   #2
Licensed electrician
Rewards Points: 1,786
The ground for the satellite needs to be connected to the grounding system for the house. Do not use the pipe as a conductor.
Old 08-21-2011, 10:10 AM   #3
Code05's Avatar
Rewards Points: 1,104
Grounding wire should be a #10 minimum.
Code05 is offline   Reply With Quote
Old 08-21-2011, 10:21 AM   #4
Lol, the satellite installers really did a bang up job, a mess of wires and splitters, coax run through the joists with the electrical, no face plates, some wires not terminated. And improperly grounded too?
How would I ground it at this point, run a line all the way to the panel?
Old 08-21-2011, 12:33 PM   #5
Rewards Points: 1,542
If the new ground wire for the satellite equipment first reaches the fat ground wire between the panel and other ground rods (or the entering cold water pipe) then it can stop there.
Old 08-21-2011, 12:37 PM   #6
Lic Elect/Inspector/CPO
Both the dish and the lead-in cable must be grounded in accordance with 810.21 and the messenger ground wire (that is part of the cable to the dish) can be used for this purpose . But, be sure you ground the grounding block with a 10 AWG ground wire in accordance with 810.21
The spliitters do not have to be grounded, since the ground is required at the dish grounding block
NJMarine is offline   Reply With Quote
equipment grounding rolan Building & Construction 1 06-18-2011 07:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 05:55 PM
