Grounding Rods For Tv Antennas - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2011, 09:04 PM   #1
Grounding rods for tv antennas
My question involves grounding rods and how to use them. My coax is coming down on the north side of my house, so I need to install a grounding block there. I was thinking of bringing the ground from the antenna down there as well and attaching them both to a new grounding rod. Then I would need to run another wire from this new grounding rod, to the grounding rod for the entire house electrical system...at least according to other threads that I've read on here and elsewhere. That other grounding rod is around the corner on the east side of my house and is about 37 feet away from where I would be installing the new one. Anyway, my question is, does that wire that's connecting the two grounding rods need to be buried? If so, how deep?
Wasatch Rebel is offline   Reply With Quote
Old 06-02-2011, 05:51 AM   #2
Lic Elect/Inspector/CPO
You can bury the ground wire. keep it right next to the foundation.
When you bring it up, install an interbonding block. The grounds get connected to the block.
NJMarine is offline   Reply With Quote
Old 06-02-2011, 07:47 AM   #3
Rewards Points: 1,418
If it is up against the foundation, there is no minimum depth. The significance of burying it at least a foot deep is to prevent accidental damage from/to rototillers, etc.
Old 06-02-2011, 08:22 AM   #4
Would I put that block next to the grounding rod for the whole house, or the grounding rod for the antenna (which is around the corner from the one for the whole house)? Or does it matter?
Old 06-02-2011, 08:23 AM   #5
Someone told me I could also attach it to the structure. I'm not sure which would be better.
grounding rods for spas scottyweis Electrical 60 09-15-2014 10:26 PM
grounding electrode conductor question bsperr Electrical 8 12-05-2009 10:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
