Grounding Rods For Spas - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-02-2010, 03:11 PM   #31
Licensed electrician
Rewards Points: 1,494
Originally Posted by Stubbie View Post
This is one Marc did in France ... notice he improved the water heater over mine.......ok I'm finished .....
And Marc wants us all to know how busy he is. Now the cat is out of the bag.
Note: no cats were harmed in the making of this post.
BTW Stubbie, is that is really a fish poacher in your back yard? We know how you like to fish
Old 09-02-2010, 11:22 PM   #32
" Euro " electrician
frenchelectrican's Avatar
Stubbie .,, shoot ya got my cat out of the bag !!! anyway thanks for the photo that is good one.
Merci.
Marc
Old 09-07-2010, 11:06 AM   #33
nice pics,
if i may, i have another question for you all. '
i am on the home stretch now. all i need is to connect to my service panel, my spa is 40a, i got the 50a spa box, so i need to get my double pull breaker for the service panel. do i need a 50a since my spa box is 50a, or is the 40a breaker the choice to get since the spa is only 40a.
scottyweis is offline   Reply With Quote
Old 09-07-2010, 11:36 PM   #34
If your spa do required 40 amp breaker then you have to use 40 amp breaker unless it stated otherwise I know many spas the amparage requirement will varies a bit useally 40 and 50 and 60 amp size is pretty common but 50 is the most common.
Double check with your manufacter tag or details on it If say 40 then you have to get 40 amp RCD { GFCI } breaker at spa panel { they are not really cheap they run anywhere from 30 to 80 Euros depending on what brand it is }
Merci.
Marc
Old 09-09-2010, 02:01 PM   #35
hey speedy. its me, scott, with the spa. i have an issue with my service panel and im hoping you can help me out.
i of course need a 50a double pull breaker for the spa, but i dont have a 2 inch spot at my panel. i have 2 vacant spots, but they are both 1 inch. now, i could move a few breakers around, but instead of doing that. is there such thing as a 50a double pull thats 1 inch in size
Old 09-09-2010, 03:01 PM   #36
Rewards Points: 330
the 240 double pole is two 1 inch breakers riveted together.may have to move one breaker up or down to get two spaces side by side.
oleguy74 is online now   Reply With Quote
Old 09-09-2010, 04:46 PM   #37
The 240v breaker pulls power from both feeds to get 240v
A 1" breaker only pulls power from one side...120v
So you do need (2) spaces side by side
Old 09-09-2010, 05:19 PM   #38
Electrical Contractor
jbfan's Avatar
Rewards Points: 400
What brand of panel, and can you post a pic?
Some panels will take a slim 50 amp 2 pole as long as you can hit both legs.
jbfan is online now   Reply With Quote
Old 09-09-2010, 05:47 PM   #39
ok,that makes alot of sense, thanks for clarifying that for me, its pretty simple when you put it that way. i should be able to juggle a breaker here or there to acomodate the double.
thanks again
Old 09-09-2010, 09:18 PM   #40
Scott.,
I know the GE load centre do have 1/2 inch breaker capale set up so with 1 inch 2 pole breakers you will have to move up or down HALF not full slot so you can hit both legs you will noticed on the bussbar tabs arrangement.
I think there is one or other brand do the same thing as well but I don't recall it at the moment.
Merci.
Marc
Old 09-10-2010, 06:46 AM   #41
Rewards Points: 746
Originally Posted by Speedy Petey View Post
No. This has never been a requirement.
Who said you did? They were wrong.
I would say that it depends on the location of the spa. I had one located about 30 feet from the house and the inspector declared it a "separate building or structure" and required a ground rod. I've had the same thing on automatic generators located only a few feet from the house. I could have argued this one since the generator is not being fed from the home, except for the battery charging circuit which falls under the single branch circuit exception.
Mark
busman is offline   Reply With Quote
Old 09-10-2010, 11:02 AM   #42
i see what you mean, byut my spa is only 7 feet from the house, in the back corner, which is about 90 feet from the service panel. and only 10 feet from my spa breaker panel.
Old 09-10-2010, 01:13 PM   #43
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Wow. Seriously? Well your guy was wrong as well. And the fact that he requested this is quite absurd.
Even if it were a separate building or structure (which it is NOT ), it would only require a ground rod if it were supplied with a feeder (which it is NOT).
If it is fed with one circuit (it IS), it does not require a grounding electrode.
If this ever comes up again you can reference NEC 250.32(A)Exception.
This is correct. A standby genset DOES require a grounding electrode.
NEC 250.30
Old 09-10-2010, 01:16 PM   #44
Rewards Points: 746
Speedy,
This one did have feeders. The spa panel (which served as the required disconnecting means) was mounted on the deck that was built around the spa, so I really couldn't argue the point. Sorry I wasn't clear in the description.
As far as the standby genset, it requires a grounding electrode, but it was connected to the house's grounding electrode, so no additional ground rod should have been required. It was not an SDS.
Mark
Old 09-10-2010, 01:20 PM   #45
Speedy,
Mark
Ahhhhh...then the panel could have required an electrode. I will say, I have NEVER had an inspector require an electrode for a spa panel. If it were mounted on it's own pedestal or "structure", and had more than one circuit in it it would definitely require an electrode.
If it was just a single circuit disconnect I cannot see requiring an electrode.
grounding electrode conductor question bsperr Electrical 8 12-05-2009 09:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 11:06 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
