Old 07-11-2012, 05:07 AM   #1
Grounding rod required?
Do I need a grounding rod for a subpanel attached to my house but on the opposite side from my main panel? about 40 ft across
swami101 is offline   Reply With Quote
Old 07-11-2012, 05:59 AM   #2
Semi-Pro Electro-Geek
As long as it's attached to the same structure, no. You only need rods if the subpanel is in a detached structure.
mpoulton is offline   Reply With Quote
Old 07-11-2012, 05:49 PM   #3
Thank you.
Old 07-12-2012, 10:52 PM   #4
Julius793's Avatar
I assume it will be fed with 4 wires is that correct?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 07-12-2012, 11:02 PM   #5
thinking your find, if its fed with 4 wire/220. Where i live a few monthes ago i hired an electrician to replace my main panel and re-use of existing panel as a sub panel in my garage. Inspector cam spendt some time looking and signed off. It has #6 wire running to it. It is 50 am service, i think the run is about 40 ft. but that is acceptable where i live. no new grounding rod was needed, however when i hd my main box upgraded, they added a ground to my water pipe and 2 new ones on m yard.
Last edited by bf514921; 07-12-2012 at 11:04 PM. Reason: duh, answer the op question
bf514921 is offline   Reply With Quote
Fuse panel grounding Cottage9 Electrical 0 07-05-2012 12:31 PM
Insulated metal grounding bushing in meter socket WillK Electrical 7 05-26-2011 10:10 AM
Load center & grounding recommendations lesp Electrical 9 04-16-2011 12:14 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Listed for grounding or not Stubbie Electrical 22 07-27-2008 11:14 AM
