-   -   Grounding rod required? (http://www.diychatroom.com/f18/grounding-rod-required-149884/)
swami101 07-11-2012 04:07 AM
Do I need a grounding rod for a subpanel attached to my house but on the opposite side from my main panel? about 40 ft across
mpoulton 07-11-2012 04:59 AM
As long as it's attached to the same structure, no. You only need rods if the subpanel is in a detached structure.
swami101 07-11-2012 04:49 PM
Thank you.
Julius793 07-12-2012 09:52 PM
I assume it will be fed with 4 wires is that correct?
bf514921 07-12-2012 10:02 PM
thinking your find, if its fed with 4 wire/220. Where i live a few monthes ago i hired an electrician to replace my main panel and re-use of existing panel as a sub panel in my garage. Inspector cam spendt some time looking and signed off. It has #6 wire running to it. It is 50 am service, i think the run is about 40 ft. but that is acceptable where i live. no new grounding rod was needed, however when i hd my main box upgraded, they added a ground to my water pipe and 2 new ones on m yard.
