Grounding Rod For Pool Filter - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2017, 04:33 AM   #1
Grounding rod for pool filter
I am moving my pool filter/pump/swg. It will be about 50' from the panel. Should I be installing a grounding rod for the new location for additional grounding? Is there any down side to installing the grounding rod? and/or should I be installing the grounding rod as an addition to the bonding grid?
xboxguy is offline   Reply With Quote
Old 04-21-2017, 06:01 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Re: Grounding rod for pool filter
No need to install the extra ground rod.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Jim Port (04-21-2017)
Old 04-21-2017, 06:43 AM   #3
Master Electrician
Rewards Points: 3,918
No grounding rod however, you must maintain the integrity of the equipotential bonding system.
brric is online now   Reply With Quote
Old 04-21-2017, 09:40 AM   #4
Rewards Points: 406
I would get an electrical permit from your local government agency which handles this. Take plenty of pictures of the area and existing wiring.
Electrical inspectors have hours where you can ask questions. Go over your plan. Ask if it is OK. Then do the work and have it inspected.
If there is anything not safe, they will point it out to you - ahead of time and at the inspection. And the best part of all is you get an expert electrician going over your work - for not too much money!
And pools can be dangerous. There have been some nasty accidents in the past. So good idea to be darn sure everything is wired in a safe manner. Up to code.
Justin_99 is offline   Reply With Quote
small engine fuel filter recommendations gunner666 Landscaping & Lawn Care 2 07-30-2014 10:17 PM
Input and output hvac Duct too small LiL-Daddy HVAC 9 07-10-2014 05:40 PM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 09:12 AM
