Grounding Rod Clamp Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 02:04 PM   #1
I recently had some siding work done on my garage and the ground wire from the switch panel was disconnected from the ground rod outside and I need to re-connect it. I can purchase a new clamp but the question is do I need to turn the main breaker off in the electrical panel before attempting to re-attach the ground wire to the ground rod on the outside (not inside the panel).
Is there anything else that I should consider before making this repair???
Thanks!!!
ET Sherman
etsherman is offline   Reply With Quote
Old 08-02-2011, 07:17 PM   #2
dSilanskas's Avatar
Just go to a electrical supply store or Home Depot or Lowes and get a ground rod clamp commonly called acron clamp. You don't have to turn off your power or anything on the panel. Just attach the wire with the clamp and your all set
dSilanskas is offline   Reply With Quote
The Following User Says Thank You to dSilanskas For This Useful Post:
etsherman (08-02-2011)
Old 08-02-2011, 09:40 PM   #3
Ok, just wanted to be sure!!!!
Much appreciated
ET Sherman
grounding rod installation amakarevic Electrical 3 07-19-2010 06:44 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 04:34 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
