Grounding Rod - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 11:06 PM   #1
Post
Grounding Rod
Depth of grounding rod issue - am in an area where there is 4" of topsoil then about 36" of clay then am faced with the Canadian Shield /rock/ therefore my question is without any ground water of any kind is 36" deep enough for the rod or must I tap into the Shield for a safe ground ?
Old Country is offline   Reply With Quote
Old 04-25-2011, 11:39 PM   #2
Sparky
Rewards Points: 510
Ground rods in the US are a minimum of 8 feet long, I assume there is a similar rule in Canada.
Techy is offline   Reply With Quote
Old 04-26-2011, 01:37 AM   #3
Scared Electrician
Saturday Cowboy's Avatar
here u can drive it at up to a 45degree angle.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 04-26-2011, 01:54 AM   #4
" Euro " electrician
frenchelectrican's Avatar
IIRC they can run at 45 angle or use the plate or run the rod hortzonal { the latter two you will need to talk the inspector and let them know what the options they can suggest due there is specfic depth they have to set }
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old Country (04-29-2011)
Old 04-26-2011, 02:03 AM   #5
whew. i didn't know that grounding rod installation has needs angle thing.. anyway, informative.
KailaM is offline   Reply With Quote
Old 04-26-2011, 03:17 AM   #6
Still Learning
in case you didnt know, you are gonna want to use a heavy duty hammer drill or small jackhammer to get that rod in the ground. unless you got some popeye arms, and in that case eat some spinach lol
thehvacguy is offline   Reply With Quote
Old 04-26-2011, 06:37 AM   #7
Lic Elect/Inspector/CPO
Grounding Rod
A ground ring could be used, or the ground rod be be put in horizontal. If I reme ber coreectly they have to be buried 30" down.
NJMarine is offline   Reply With Quote
The Following User Says Thank You to NJMarine For This Useful Post:
Old 04-26-2011, 06:56 AM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
It doesn't need the "angle thing". It is simply allowed.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
grounding electrode conductor question bsperr Electrical 8 12-05-2009 10:23 AM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 12:06 PM
Grounding light box n0c7 Electrical 10 10-06-2008 04:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
