-   -   Grounding Rod (http://www.diychatroom.com/f18/grounding-rod-102734/)
Old Country 04-25-2011 10:06 PM
Grounding Rod
Depth of grounding rod issue - am in an area where there is 4" of topsoil then about 36" of clay then am faced with the Canadian Shield /rock/ therefore my question is without any ground water of any kind is 36" deep enough for the rod or must I tap into the Shield for a safe ground ?
Techy 04-25-2011 10:39 PM
Ground rods in the US are a minimum of 8 feet long, I assume there is a similar rule in Canada.
Saturday Cowboy 04-26-2011 12:37 AM
here u can drive it at up to a 45degree angle.
frenchelectrican 04-26-2011 12:54 AM
IIRC they can run at 45 angle or use the plate or run the rod hortzonal { the latter two you will need to talk the inspector and let them know what the options they can suggest due there is specfic depth they have to set }
Merci.
Marc
KailaM 04-26-2011 01:03 AM
whew. i didn't know that grounding rod installation has needs angle thing.. anyway, informative. :thumbup:
thehvacguy 04-26-2011 02:17 AM
in case you didnt know, you are gonna want to use a heavy duty hammer drill or small jackhammer to get that rod in the ground. unless you got some popeye arms, and in that case eat some spinach lol
NJMarine 04-26-2011 05:37 AM
Grounding Rod
A ground ring could be used, or the ground rod be be put in horizontal. If I reme ber coreectly they have to be buried 30" down.
Speedy Petey 04-26-2011 05:56 AM
It doesn't need the "angle thing". It is simply allowed.
