Grounding Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 05:59 PM   #1
grounding questions
Ok, I am installing a new 200amp service. I have a meter socket without a disconnect. I have a GE 200 amp 32 space panel. I get confused with the way to ground the system. Let me know if this is right. I run my 2 hots and neutral from power co to meter socket. Then the same wires plus an insulated ground to the breaker box. Then a bare ground from ground side of panel to the ground rods? The neutral and ground bars are tied together at the bottom with metal. That should stay right? I have only done a few of these so far and every panel has looked different.
firedude00 is offline   Reply With Quote
Old 01-24-2011, 06:25 PM   #2
WaldenL's Avatar
Rewards Points: 268
Man I'm glad the word "fire" is in your name. :-) If you're not sure how to set this up I don't think I'd be doing the service main install. I'm not saying you're design is right or wrong, just that a 200A main isn't the place to play if you're not sure yourself.
WaldenL is offline   Reply With Quote
Old 01-24-2011, 06:55 PM   #3
Bigplanz's Avatar
Rewards Points: 948
This is the kind of job you hire somebody for who knows what they're doing, like a licensed electrician.
Bigplanz is offline   Reply With Quote
Old 01-24-2011, 07:31 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by firedude00 View Post
Let me know if this is right.t.
no, it's not right.
Old 01-24-2011, 07:33 PM   #5
After looking around I guess I just have to come from the ground bar in the panel to the ground rods. The panel is the first disconnect, so I think I am thinking right at the moment
Old 01-24-2011, 07:53 PM   #6
nap
You talking to me?
nap's Avatar
that isn't the part I was referring to.
Old 01-24-2011, 07:57 PM   #7
what are u referring too?
Old 01-24-2011, 08:10 PM   #8
nap
You talking to me?
nap's Avatar
you do not run 4 conductors from the meter to the panel.
With a GE panel, there is "bonding" screw that comes with the panel. It screws through the neutral bar and becomes your main bonding jumper (neutral to ground connection). The neutral and ground bars, if both are isolated, have to be bonded to each other. Your GEC will run from your neutral or ground bar to the grounding electrodes. The size is determined by the type of grounding electrode being used and the service size.
I'm betting the bars you are referring to as grounding bar and neutral bar are actually just 2 neutral bars. If I remember correctly, GE uses dual neutral bars in the manner you describe. The grounding bar is often a separately installed bar that attaches the the panel tub.
Provide the panel model number and it can be checked.
Now, you have actually shown your lack of experience in electrical work so please don't go and kill yourself by playing with things you really shouldn't be working with.
The Following User Says Thank You to nap For This Useful Post:
LyonsElecSupply (01-24-2011)
Old 01-24-2011, 09:14 PM   #9
Electrical Supplier
Rewards Points: 150
You have the potential to damage equipment, miswire, cause damage to your house or KILL yourself.....get someone who has an understanding of code, and how to install a service......I bet a few bucks there are other problems wrong with your panel install.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-24-2011, 09:28 PM   #10
I can relate to your desire to do things yourself, but this is one of those times when you should hire a professional.
cep89 is offline   Reply With Quote
The Following User Says Thank You to cep89 For This Useful Post:
Speedy Petey (01-25-2011)
Switch Box Grounding Questions MartinD Electrical 5 01-26-2010 11:00 PM
grounding of main panel and sub panel in older house linkysys Electrical 2 10-01-2009 05:34 PM
Grounding Method Steelhead Electrical 6 02-05-2009 12:06 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
