Grounding Questions - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 11:53 AM   #16
Code05's Avatar
Rewards Points: 1,104
Originally Posted by brric View Post
It would seem to me you would be far better served learning this from your 'well qualified' uncle. Just my opinion.
Not a chance in hell that a 20 year old with limited experience will pass that test IMO.
Code05 is offline   Reply With Quote
Old 09-08-2011, 11:55 AM   #17
Yes he has helped me some but he is very busy and can't always be there when I have a question but this really has nothing to do with my questions
ZBat910 is offline   Reply With Quote
Old 09-08-2011, 11:57 AM   #18
Everyone I really appreciate the kind words.. What does it matter if you don't think I'll pass if you are going to post on here please make it relevant to my questions
Old 09-08-2011, 12:01 PM   #19
Code05's Avatar
Did you look at the links I posted?
I am not trying to discourage you from an electrical career, but rather prepare for what it is really like.
It is far more complex than most people realize.
Old 09-08-2011, 01:47 PM   #20
I appreciate you trying to show me it is complicated and difficult but I do already understand that. I am nottaking the test anytime soon and I'm going to do several months of studying and I did take a look at your links I know there is valuable info there but I had to come into work so I wasn't able to look at it all. I just really want to understand why you use 3 or 4 wire
Cables between meter and main panel and where to properly ground these boxes. I know there is much more than that to it but I want to understand general idea of it and progress on my own that way. I have scowered
The net trying to find the exact info I needed but couldn't find it
So I posted here.
Old 09-08-2011, 02:01 PM   #21
I=E/R
a7ecorsair's Avatar
So the neutral current only has one path back to its source.
a7ecorsair is offline   Reply With Quote
Old 09-08-2011, 02:05 PM   #22
Code05's Avatar
250.24 Grounding Service-Supplied Alternating-Current
Systems.
(A) System Grounding Connections. A premises wiring
system supplied by a grounded ac service shall have a
grounding electrode conductor connected to the grounded
service conductor, at each service, in accordance with
250.24(A)(1) through (A)(5).
(1) General. The grounding electrode conductor connection
shall be made at any accessible point from the load end
of the service drop or service lateral to and including the
terminal or bus to which the grounded service conductor is
connected at the service disconnecting means.
(5) Load-Side Grounding Connections. A grounded conductor
shall not be connected to normally non–currentcarrying
metal parts of equipment, to equipment grounding
conductor(s), or be reconnected to ground on the load side
of the service disconnecting means except as otherwise permitted
in this article.
250.24(D) Grounding Electrode Conductor. A grounding electrode
conductor shall be used to connect the equipment
grounding conductors, the service-equipment enclosures,
and, where the system is grounded, the grounded service
conductor to the grounding electrode(s) required by Part III
of this article. This conductor shall be sized in accordance
with 250.66.
Old 09-08-2011, 02:26 PM   #23
Code05's Avatar
I suggest the OP start reading article 250. What fun.
Old 09-08-2011, 03:04 PM   #24
would anyone happen to have a picture that shows inside a meter the connection from the service cables changing it to 4 wires? i just get confused as to where i hook the 4th wire if you get what im saying. some panels dont have lugs in them for a 4th wire so thats throwing me. i know from the meter with 4 wires to the main panel you hook the 2 hots in the appropriate lugs the neutral in the middle of those and the bare ground to the ug for the ground bar. just confused about the other end.
Old 09-08-2011, 03:09 PM   #25
Too Short? Cut it Again!
Electricity in the hands of fools can be such fun to watch. But the fools tend not to live so long.
Old 09-08-2011, 03:13 PM   #26
Master Electrician
Rewards Points: 3,678
In general, the only time there are four wires from the meter to the panel is when there is a three phase service.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
DangerMouse (09-08-2011)
Old 09-08-2011, 03:19 PM   #27
Code05's Avatar
Yep, POCO usually does not allow a GEC connection in meter, although tis legal.
Old 09-08-2011, 03:26 PM   #28
Come on! Do we on this site really want to suggest this sort of thinking is a DIY pursuit?
Old 09-08-2011, 03:43 PM   #29
Code05's Avatar
Op is out of his league and won't admit it. I am thinking " bull puckey" on his experience.
To the OP, if I am wrong I will apoligize, but these are 1st year apprentice or DIY questions. Do not try and BS us. Sparkies can tell.
Old 09-08-2011, 03:50 PM   #30
I=E/R
a7ecorsair's Avatar
Fourth wire? Think of it this way for residential wiring; you don't have four wires until after the service disconnect.
I am quite sure i have 8000 hours but i know i definitely have the 4 years
And you are asking these questions?
grounding questions firedude00 Electrical 9 01-24-2011 09:28 PM
Switch Box Grounding Questions MartinD Electrical 5 01-26-2010 11:00 PM
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 03:07 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
