Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 06:23 PM   #1
Grounding Question
I just replaced my 100amp 20 slot panel with a 100amp 30 slot panel and I have a question about the grounding. I also have a disconnect fuse\panel in the basement about 3ft from the meter and then the main panel is about 10' from there. The only current ground I have is an 8awg wire attached to my copper pipe and to the ground screw on the disconnect. I have read that if I have a copper pipe buried at least 10 ft out, my ground needs to be attached to the main pipe within 5' of it coming into the basement.
If this is the case, does it need to be grounded to the disconnect or the main 100amp panel?
Also, does the ground and the neutral need to be separated at the main breaker panel because of the disconnect?
Oh, one last question. Do I have to have the grounding rod as well as the copper pipe ground? If so, where is this one grounded to?
Thank, Scott...
smuth10 is offline   Reply With Quote
Old 10-14-2010, 08:06 PM   #2
I=E/R
a7ecorsair's Avatar
How does the power get from the meter to your new panel? Do the wires from the meter go the disconnect/fuse box you mentioned first and then to the panel?
a7ecorsair is offline   Reply With Quote
Old 10-14-2010, 08:13 PM   #3
Yes, they do
Old 10-14-2010, 09:45 PM   #4
I=E/R
a7ecorsair's Avatar
Thank, Scott...
In your disconnect you should have the ground wire connected to the same bus bar as the neutral from the meter. You should then have four wires going to your 100 amp panel - 2 hots, a neutral, and a ground. In your 100 amp panel the neutral and the ground bus are not connected.
Old 10-15-2010, 10:18 AM   #5
I can run a ground from the disconnect to the main panel without a problem, but with the way the wires were run to the main panel, there is no way I would be able to separate the ground and neutral. What is the downfall of not having it connected this way? Is there another work around to have this setup so that there is no real danger?
Old 10-16-2010, 07:46 AM   #6
I=E/R
a7ecorsair's Avatar
Why can't you separate the two bus bars? You may have to extend some of the wires but as long as only one white wire is under a screw on the neutral bar you will be ok. You can put two ground wires under a screw on the ground bar.
What type of wire runs from the disconnect to this panel and what size? Is it copper or aluminum?
Old 10-16-2010, 08:18 AM   #7
I have plenty of room on the two bars, I just didn't think it was kosher to wire nut extensions inside of the box to run the wires around to the other bar. I will do this as soon as I have a chance. The wire from the disconnect to the main panel is new 2awg alum. 3 wires, the two hots and the common.
I am thinking of running two new grounding rods outside and grounding these to the disconnect and then running a separate ground for the main panel to the copper pipe coming in the basement. I figure two grounds are better than one
Old 10-16-2010, 11:40 AM   #8
Licensed electrician
Rewards Points: 1,464
As was already stated the feeder to the panel from the disconnect needs to be 4 wires, not 3 like you have.
The ground for the panel comes from the disconnect, not a water pipe.
Old 10-16-2010, 04:16 PM   #9
Alrighty then. Thank you!
Old 10-13-2013, 11:42 PM   #10
So Jim, what you're saying is that from the sub-panel back to the disconnect you need four wires (two hot legs, a neutral, and a ground) but at the disconnect the neutral and the ground can come together? I think what I'm hearing is that between the main panel and the disconnect three wire is ok (two hot and a neutral) but from the disconnect to the sub-panel the ground and the neutral must be separate? Can you explain why this is how it must be?
Keegans is offline   Reply With Quote
Old 10-14-2013, 05:49 AM   #11
Rewards Points: 774
You cannot just "run" a ground wire, you must replace the existing cable with a properly sized 4-conductor cable.
In addition you need to verify the neutral/ground bar in the subpanel which will become the neutral bar is not bonded (grounded) to the back box.
Know A Little is offline   Reply With Quote
Grounding a Square Box <--newbie question dgates12 Electrical 20 01-06-2010 06:02 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 04:14 AM
