Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2009, 12:21 AM   #1
Question
Grounding question
Something that has vexed me for a while now. Why are mounted fixtures like ceiling lights or wall scounces grounded but table lamps aren't?
hayewe farm is offline   Reply With Quote
Old 03-15-2009, 05:48 AM   #2
Master Electrician
JohnJ0906's Avatar
The answer probably lies with the fact that the National Electric code applies to hardwired/permanently mounted fixtures, but doesn't apply to lamps at all.
The NEC requires light fixtures to be grounded.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 03-15-2009, 09:21 AM   #3
joed's Avatar
Rewards Points: 12,008
Plug in fixtures undergo UL testing that determines if grounding is needed. Most of the time it is not needed because they are not made out of metal. You can't get a shock from wood or plastic. Plastic ceiling fixtures won't have a ground either.
Old 03-15-2009, 11:16 AM   #4
Rewards Points: 150
I was about to write that a metal lamp will have a third equipment ground prong on the plug. Then I looked at my all metal desk lamp and it doesn't, hmmmm now that is vexing.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 03-15-2009, 11:30 AM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I always thought it was because they were considered "double insulated". Here's an excerpt for the definition
Double insulated or class 2 electrical appliances are products that have been designed in a way so as not to require a safety connection to electrical earth (These products must NOT have a safety connection to Earth).
These products are required to prevent any failure from resulting in dangerous voltage levels becoming exposed causing a shock etc. This must be done without the aid of an earthed metal casing. Ways of achieving this include double layers of insulating material or reinforced insulation protecting any live parts of the fitting.
wirenut1110 is offline   Reply With Quote
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 02:49 PM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
