Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 05:41 AM   #1
Grounding question
The area I am working in is still using 1999 code. All of the main pannels up the street are using the city water lines for the service grounding electrode. Everything is concrete with no way to put in a ground loop except. I have the front porch floor riped out. If I put a ground loop under the porch will this voilate any code. Yes I will keep the water pipe bonded.
Dilligaf77 is offline   Reply With Quote
Old 03-08-2008, 05:50 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,888
I can only assume you are using the wrong term, "ground loop". I think you want to install another electrode (ground rod)?
It is perfectly fine to run the wire that way. Nothing is written that it must remain accessible.
Old 03-08-2008, 01:40 PM   #3
Rewards Points: 88
The easiest way would be to drill a hole in the concrete. Then drive the grounding electrode or two if required.
Sub-panel grounding question. gesoneguy Electrical 31 02-22-2008 09:25 AM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 02:49 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
