Grounding Question! - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2008, 10:16 AM   #1
Grounding Question!
Is it legal to use the neutral wire as a ground. My house is old and wired using the old 2 prong style. I need to put in a GFCI in my kitchen and bath in order to sell my house.
luweee is offline   Reply With Quote
Old 02-03-2008, 10:21 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
ABSOLUTELY NOT!!!!!
This can be VERY dangerous and can cause anything metallic to become live in the event of a problem.
DO NOT even consider doing this. PLEASE.
A GFI does NOT need a ground to function, and can be a legal safety solution to an ungrounded circuit.
Old 02-03-2008, 10:49 AM   #3
Sparrky
Roger that...do NOT use the Neutral...put the GFCI device iwth hot and neutral...observing WHERE line form pwer is connected and where the load is connected on the device and you are safe and good to go
Kingsmurf is offline   Reply With Quote
Old 02-03-2008, 10:55 AM   #4
thanks
Thanks to the both of you!
And Speedy Petey thanks again. you have answered several of my questions.
THanks again
Old 02-03-2008, 05:03 PM   #5
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
When putting in a GFCI that has no ground don't forget to mark it NO EQUIPMENT GROUND also mark any other recepticals connected to it upstream with the same thing. But my question is why do you have to do that to sell your house your house is grandfathered. was it that the home inspector told you that you have to?
Pudge565 is offline   Reply With Quote
Old 02-03-2008, 05:41 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Like Pudge said. If it was code when it was built, then you do not have to put gfci's in, unles you want to, or a local requirement
Old 02-03-2008, 09:48 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
in some localities, a house is required to be brought up to code, or at least certain parts of it, when it is sold. Two cities near me require such updates.
No grandfathering allowed.
Old 02-04-2008, 11:32 PM   #8
Electrician philosopher
SP is the man
Andy in ATL is offline   Reply With Quote
Old 02-05-2008, 05:51 AM   #9
waiting for spring
arichard21's Avatar
Rewards Points: 150
Ya, how could you not like him???
arichard21 is offline   Reply With Quote
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
Another Dumb question - Self grounding outlets robertmee Electrical 9 10-25-2007 01:49 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 04:14 AM
