Grounding Question - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 08:25 AM   #31
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Originally Posted by darren View Post
The surface mount box inside a wall gave that away to me.
Since when is a 1900 box specifically a surface mount box?
Have you never used a side-strap 1900?
The Following User Says Thank You to Speedy Petey For This Useful Post:
brric (08-05-2012)
Old 08-05-2012, 08:48 AM   #32
Master Electrician
Rewards Points: 3,676
Originally Posted by Michael Thomas View Post
No bushings are required on MC cable, but... it looks to me like there is a paper interior wrap around the conductors (the brown area) visible where they exit the connector, which would make that AC not MC (at least based on the materials I encounter).
I never said the original picture was MC. It is clearly AC, the bonding strip is visible at the connector, ad the red head may or may not be visible in such an installation. What I said was that your picture is showing MC not AC.
brric is online now   Reply With Quote
Old 08-05-2012, 08:51 AM   #33
Master Electrician
Looks like a mud ring on a 4 square to me.
Old 08-05-2012, 09:32 AM   #34
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I don't see an anti-short bushing:
in that last picture:
which suggests that this may have been an unpermitted, uninspected DYI wiring job.
If so, there may not be an appropriate, uninterrupted low-impedance ground path to all the outlet boxes.
Here is a picture of that same box... but the left side.
I see a anti-short. so, im guessing the job was done by a competent electrician.
Old 08-05-2012, 10:04 AM   #35
Electrician
Rewards Points: 760
Nope did not know they made them, may be a US thing or something I have not seen yet.
The only time I have used those boxes(which are called 1110's where I am from, got love how everybody has different names for the same thing) were for surface work.
darren is offline   Reply With Quote
Old 08-05-2012, 10:06 AM   #36
E2 Electrician
So what box do you use for MC/AC, EMT, RMC, PVC, type wiring on the interior of walls?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Speedy Petey (08-05-2012)
Old 08-05-2012, 11:24 AM   #37
Master Electrician
Looks more like a 4 inch square with single gang plaster ring to me.
Edit: already been said, didn't notice page two.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-05-2012, 11:28 AM   #38
Master Electrician
It's not an 1110, that's a utility box, its a 4inch square with plaster ring and they make em every day here. Side strap as well. I think your confusion stems from the fact you think its the wrong box.
The Following User Says Thank You to andrew79 For This Useful Post:
stickboy1375 (08-05-2012)
Old 08-05-2012, 11:30 AM   #39
Master Electrician
We don't have metallic sheath cable without bare ground wire so we just call it all bx. Some has an insulated ground for isolated ground installs. As for boxes we use the same type you do just call them different names.
Grounding question for subpanel mn1247 Electrical 26 09-19-2011 11:41 AM
Grounding a Square Box <--newbie question dgates12 Electrical 20 01-06-2010 07:02 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
