Grounding Question - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 10:43 AM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Raym50 View Post
Great, thanks. Sorry to sound like a major idiot - but it sounds like so long as the screws are touching the metal box (which they are because the screws go into the metal box), then I'm good?
As long as the screws are metal. then yes, you are correct.
Old 07-28-2012, 10:49 AM   #17
Rewards Points: 126
The switch ground should be connected to the box.
Old 07-28-2012, 10:50 AM   #18
E2 Electrician
Why? Check out 404.9 (B)(1)
Old 07-28-2012, 11:06 AM   #19
Very helpful, thank you! I have another question which I will start a new thread for...
Raym50 is offline   Reply With Quote
The Following User Says Thank You to Raym50 For This Useful Post:
stickboy1375 (07-28-2012)
Old 07-28-2012, 11:47 AM   #20
Electrician
Rewards Points: 788
Originally Posted by stickboy1375 View Post
YEP, AC type wiring, the outer jacket is the grounding conductor, which bonds the box.
Is that still code in the NEC.
darren is offline   Reply With Quote
Old 07-28-2012, 11:49 AM   #21
E2 Electrician
Is what still code? Using the jacket of ac type cable as the equipment ground? Yes it is. This cable is still produced today. As long as it contains a #16 bonding strip, there is nothing wrong with this method.
Old 07-28-2012, 01:05 PM   #22
Electrician
Rewards Points: 788
So if it does not have a bonding strip can you use just the jacket for your bond.
Old 07-28-2012, 01:30 PM   #23
Semi-Pro Electro-Geek
Rewards Points: 2,922
No, but that type of AC cable is not still made. Without a bonding strip the jacket cannot be used for grounding, and the cable is considered ungrounded.
mpoulton is offline   Reply With Quote
Old 07-28-2012, 01:33 PM   #24
E2 Electrician
No, you can't.
Old 07-28-2012, 01:57 PM   #25
Electrician
Rewards Points: 788
Ok that is what I thought, can you still by AC with a bonding strap.
Old 07-28-2012, 01:58 PM   #26
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Absolutely.
Old 08-05-2012, 05:25 AM   #27
Chicago, IL
Michael Thomas's Avatar
I don't see an anti-short bushing:
in that last picture:
which suggests that this may have been an unpermitted, uninspected DYI wiring job.
If so, there may not be an appropriate, uninterrupted low-impedance ground path to all the outlet boxes.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 08-05-2012, 06:54 AM   #28
Master Electrician
Rewards Points: 3,810
The top picture you are showing is MC cable. Anti short bushing are not required for MC cable.
brric is offline   Reply With Quote
Old 08-05-2012, 07:14 AM   #29
Chicago, IL
No bushings are required on MC cable, but... it looks to me like there is a paper interior wrap around the conductors (the brown area) visible where they exit the connector, which would make that AC not MC (at least based on the materials I encounter).
Old 08-05-2012, 07:20 AM   #30
Electrician
Rewards Points: 788
The surface mount box inside a wall gave that away to me.
Grounding question for subpanel mn1247 Electrical 26 09-19-2011 10:41 AM
Grounding a Square Box <--newbie question dgates12 Electrical 20 01-06-2010 06:02 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 09:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 04:14 AM
