Grounding Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 09:44 AM   #1
Grounding question
Hi. My house Was built in 2005. All new electrical. I am now looking to replace the light switches with lutron dimmers and there is no grounding wire in my light switch boxes. Is that possible? It looks like there is a ground wire in my basement connected to the water main or sewer pipe.
Could it be that the actual light switch box (which is metal) is grounded and there is no actual ground wire connected to the switches? My current light switches have a grounding screw, but no wire is connected to it.
Any thoughts or input would be greatly appreciated.
Raym50 is offline   Reply With Quote
Old 07-28-2012, 09:53 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
For a house that new there HAS to be an equipment ground. If the boxes are metal maybe they used AC cable where the sheathing is the ground?
The bond/ground wire to the water pipe is completely irrelevant to the equipment ground in the switch and receptacle boxes.
Old 07-28-2012, 10:17 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I agree, I would very shocked if no equipment ground was installed.
Old 07-28-2012, 10:22 AM   #4
E2 Electrician
Take a picture for the most accurate response to your question.
Old 07-28-2012, 10:27 AM   #5
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Wonder if the OP is in Chicago, don't they have to run pipe in houses?
wirenut1110 is offline   Reply With Quote
Old 07-28-2012, 10:27 AM   #6
Electrician
Rewards Points: 760
Do they still make cable like that( i assume ac is similar to our bx with an armoured metal outside). All our BX has a bonding conductor in it.
Do you live in the Chicago area and have EMT run all over your house, if so the emt would be your bond(technically it is not a ground but a bond back the grounding conductor)
darren is offline   Reply With Quote
Old 07-28-2012, 10:32 AM   #7
E2 Electrician
AC is still used and sold today.... The BX name is just electrical 'slang' for AC type cable.
Old 07-28-2012, 10:44 AM   #8
Good one. . .
The Following User Says Thank You to Yoyizit For This Useful Post:
Evstarr (07-28-2012)
Old 07-28-2012, 10:45 AM   #9
E2 Electrician
Originally Posted by Yoyizit View Post
Good one. . .
thanks.
Old 07-28-2012, 11:14 AM   #10
kbsparky's Avatar
A house built as recently as yours with metal switch boxes most likely has metal raceway or metallic-sheathed cables that provide the equipment grounding means.
In cases such as this, the metal screws holding the switch in the box may be sufficient for grounding purposes.
However, if you really want to ensure a good grounding connection then install a green screw into the back of the box, and a pigtail jumper from there to the grounding terminal on your switches and dimmers.
-KB
Old 07-28-2012, 11:24 AM   #11
Thanks all. I appreciate all the feedback. Here are some pictures. THis happens to be a 3 way switch. Do they inform of you anything?
Grounding question-photo.jpg   Grounding question-photo1.jpg   Grounding question-photo2.jpg   Grounding question-photo3.jpg
Old 07-28-2012, 11:28 AM   #12
E2 Electrician
YEP, AC type wiring, the outer jacket is the grounding conductor, which bonds the box.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Raym50 (07-28-2012), Speedy Petey (07-28-2012)
Old 07-28-2012, 11:31 AM   #13
OK, so what do I do with the green ground wire coming from the new lutron light switch?
Old 07-28-2012, 11:33 AM   #14
E2 Electrician
I generally just cap them off and use the 6-32 screws as the bonding method. As a side note, we only ground switches by chance a metal faceplate is installed, if everything were plastic, this would serve no useful purpose.
Old 07-28-2012, 11:42 AM   #15
Great, thanks. Sorry to sound like a major idiot - but it sounds like so long as the screws are touching the metal box (which they are because the screws go into the metal box), then I'm good?
Grounding question for subpanel mn1247 Electrical 26 09-19-2011 11:41 AM
Grounding a Square Box <--newbie question dgates12 Electrical 20 01-06-2010 07:02 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
grounding to water pipe question eastvantrading Electrical 6 12-20-2006 10:49 AM
Question on Grounding ayudi General DIY Discussions 2 12-11-2006 05:14 AM
