Grounding A Plug - Electrical - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 11:10 PM   #1
grounding a plug
can i ground a receptacle if it does not have a grounding conductor by attaching a jumper from the neutral of the plug to the ground screw ?
junction box is offline   Reply With Quote
Old 03-15-2011, 11:33 PM   #2
Scared Electrician
Saturday Cowboy's Avatar
No NO! thats very dangerous, we call it a bootleg ground. It will give the illusion of a ground but will not provide any of the benefits of a grounded system.
The quick and easy way to fix this problem is to install a GFI.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-16-2011, 07:43 AM   #3
Rewards Points: 1,500
It is perfectly okay to run a makeshift ground wire from the receptacle, roughly (for example exposed along baseboards) following the route of the wiring and back to the panel.
If this ground wire reaches the grounding electrode conductor (the fat bare wire from the panel to a ground rod or water pipe) first, it may stop there.
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Replacement plug for an old box freezer brich Electrical 1 05-11-2010 06:44 AM
removed old romex (added new wire) and added a plug doesn't work now? Limit54 Electrical 9 11-08-2009 09:03 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
