Grounding In A Plastic Receptacle Or Junction Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 08:36 PM   #1
Grounding in a plastic receptacle or junction box
Do you need to ground the recepticle in a plastic box or do you need to ground the incoming or two outgoing lines in a plastic junction box?
Last edited by smcgarry9; 10-19-2011 at 08:39 PM. Reason: I did not get the reply, I needed to remove a blocker in my computer
smcgarry9 is offline   Reply With Quote
Old 10-19-2011, 08:41 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
All grounds must be connected to each other and to the receptacle.
Old 10-20-2011, 04:45 AM   #3
Rewards Points: 193
Hmmmmmm. I accept that should be the case, but um. Hmm. Where is the logic in attaching a ground to a plastic receptacle? Last I checked, plastic doesn't conduct electricity, it melts.
I don't mean to nitpick, but I just wanted to clarify to the OP that you were probably referring to metal receptacle boxes on that last part there. (Unless I'm wrong, where proof that a plastic box needs grounding is shown, I'll accept defeat as long as it's a damn good reason ).
From what I think I know, the plastic receptacle should only be utilized with something that brings a ground into the box (typ. NM cable- Romex or whatever) and that ground is attached to the neutral bus bar in the breaker panel.
scyarch is offline   Reply With Quote
Old 10-20-2011, 05:34 AM   #4
Master Electrician
Rewards Points: 3,918
You DON'T ground the plastic box. Ypu ground the receptacle so that when you plug in a grounded piece of equipment it is grounded through the receptacle to an equipment grounding conductor.
brric is offline   Reply With Quote
The Following 4 Users Say Thank You to brric For This Useful Post:
Code05 (10-20-2011), gregzoll (10-20-2011), jbfan (10-20-2011), SD515 (10-20-2011)
Old 10-20-2011, 10:33 AM   #5
Rewards Points: 193
Oh.. OOPS! My lack of sleep was getting to me. I read receptacle and I forgot the receptacle was the plug, not the box. My bad
Old 10-20-2011, 11:04 AM   #6
Rewards Points: 6,652
No, the receptacle is the device that you plug the load into. The load being a tv, drill, coffee pot, oven, etc.
The Following User Says Thank You to gregzoll For This Useful Post:
Code05 (10-20-2011)
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 02:07 PM
Receptacle Rating question Ultrarunner2017 Electrical 19 12-20-2008 06:20 PM
Receptacle Rating question Ultrarunner2017 Electrical 5 12-18-2008 05:36 PM
Plastic "Old Work" wall box - Grounding Screws? strohs19 Electrical 4 01-14-2006 06:46 PM
