Grounding Pigtails - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-19-2013, 05:46 PM   #31
Dana56's Avatar
Originally Posted by Jim Port
That might be covered in the jobs specs, but it is not in the NEC. The NEC still considers metallic conduit a suitable ground.
Your experiences and preferences are above what is required.
Pipe can become energized if ground is lost had a buddy grab an energized pipe nearly got killed thats why its good practice to pull a ground along with current carrying conductors in pipe
Dana56 is offline   Reply With Quote
Old 04-19-2013, 05:48 PM   #32
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by Dana56 View Post
Really? Here in jersey its noted all the time to pull ground...had a friend grab a
Pipe that became energized hot hurt bad.. Thats why a ground shouldb pulledwhether required or not
The EGC could just as easily be compromised.... Pulling a EGC does not guarantee anything, other than more cost to the installation.
Old 04-19-2013, 05:50 PM   #33
E2 Electrician
We all get your opinion on pulling a EGC vs using the conduit as the grounding conductor, but your opinion on one being better is invalid.
Old 04-19-2013, 05:50 PM   #34
Rewards Points: 590
Where, exactly, was the pipe getting its potential from if it was in the ground?
operagost is offline   Reply With Quote
Old 04-19-2013, 05:52 PM   #35
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
Had that happen to me only they had used the pie as a neutral also.
I have always pulled a ground after that.
Old 04-19-2013, 05:56 PM   #36
E2 Electrician
This is one of those opinions in the trade that is just silly, Either method is an acceptable one, either method can be become a hazard when the grounding means is compromised, in either scenario, it can happen. If someone is so worried about a circuit being a shock hazard, why not take it to the next step and GFCI protect every circuit.... that will cure your worries.
Old 04-19-2013, 10:06 PM   #37
Dana56's Avatar
I didnt say it was better i just say i like to pull the ground wire i get the minimum requirements i just say i like to do a little more amd in my experience anyway its always called for on prints to do so.. I get it i really do not trying to argue
Old 04-20-2013, 02:00 AM   #38
Dana56's Avatar
Two is better than one, its not required yes we all get that thank u
Old 04-20-2013, 02:17 AM   #39
Dana56's Avatar
We all get it its not required but majority still pulls a ground nowadays
Old 04-20-2013, 02:18 AM   #40
Dana56's Avatar
[QUOTE="Dana56"]
Old 04-20-2013, 03:29 PM   #41
Dana56's Avatar
It was energized from a moron not using wirenuts and pipe came in contact with voltage but pipe had a combination of compression and set screw couplings (both poorly tightened) entering panel with no locknut..... Always pull a ground its good practice to do so even if its "acceptable" not to
Old 04-20-2013, 03:30 PM   #42
E2 Electrician
So... someone terminated a conduit without a locknut, had poorly tightened fittings, but you believe this same person is capable of terminating a ground wire properly?
Old 04-20-2013, 03:37 PM   #43
Dana56's Avatar
Hell no thats the problem theres too many poor trained "electritians" that do this kind of stuff and i just suggest that ppl should pull a ground in there conduits when installing new. And never rely on a yoke of an outlet always pigtail... Yes the same moron can come in and cut your ground somehow but cant do nithin 'bout that.
Old 04-20-2013, 03:40 PM   #44
E2 Electrician
Im just not following your logic... but o'well... I dont see the point in pulling in a ground wire if they are incapable of assembling a conduit system, I don't see how they would be capable of terminating a wire under a screw?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Dana56 (04-20-2013)
Old 04-20-2013, 03:48 PM   #45
Dana56's Avatar
No your rite they probably couldnt because whoever did that in the first place didnt understand what they was doing probably a maintenance guy or something with no business doing electric work... For new applications by qualified personnel a ground should be pulled so when morons come in later and tinker with pipe the ground is less likely to be compromised so long as the ground also isnt cut but at least u double your chance... I get its not required 20amp or less but i do it and its always specked out to do so by the "genius" elect engineers
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 10:25 PM
Replacing Light Fixture with No Ground Wire in Home panorama Electrical 42 09-14-2012 10:35 AM
Bare grounding pigtails? smata67 Electrical 2 05-27-2012 08:27 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 03:54 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
