Grounding Pigtails - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 10:25 PM   #16
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by Dana56 View Post
Bonding bushings or locknuts mite be required too if the box has concentric knockouts just another nice opinion )
Code reference?
Old 04-18-2013, 10:29 PM   #17
Dana56's Avatar
Originally Posted by k_buz
Code reference?
Inspectors sometimes require it i know for me they have and why argue just do it it dont take much to go a little bit above and beyond in the workplace
Dana56 is offline   Reply With Quote
Old 04-18-2013, 10:30 PM   #18
k_buz's Avatar
Because in a residential application it is not necessary (<250V).
Old 04-18-2013, 10:35 PM   #19
Dana56's Avatar
Yes i guess so i dont do any residential at all im just in a commercial state of mind.. Only residential i did was my own new house and its wired like a commercial building lol
Old 04-18-2013, 11:52 PM   #20
Rewards Points: 508
Send a message via AIM to theatretch85
When ever I run conduit, I always pull a ground where the circuit will be feeding outlets (especially in a garage). If it's just lighting, then I don't pull a separate ground and just use the conduit. I don't think it's that much extra work to ground the device and bond to the box at the same time, but that's how I've always done it so its not a big deal for me.
theatretch85 is offline   Reply With Quote
The Following User Says Thank You to theatretch85 For This Useful Post:
Dana56 (04-19-2013)
Old 04-19-2013, 05:29 AM   #21
Rewards Points: 349
Always pigtail grounds to box and device no matter what it dont take much and its good practice. Dont think anybody relies on conduit as ground anymore, u always pull a ground in pipe
YOU may not use conduit for a grounding path, but it is quite common in industry to do so. A correctly installed conduit system is extremely effective. My home is wired in NM, so it's ground wires all over. But if it had been in conduit.......?
Blanket statements like that are misleading.
al_smelter is offline   Reply With Quote
The Following User Says Thank You to al_smelter For This Useful Post:
Dana56 (04-19-2013)
Old 04-19-2013, 06:01 AM   #22
Rewards Points: 764
Originally Posted by Jim Port View Post
Note that only applies to surface mounted boxes and certain covers. Flush mount needs both to be bonded together.
That's true for receptacles, but not for snap switches. Any snap switch attached to a metal box with metal screws is considered grounded.
Mark
busman is offline   Reply With Quote
Old 04-19-2013, 06:04 AM   #23
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
No, they wouldn't....
Old 04-19-2013, 07:51 AM   #24
Dana56's Avatar
No they wouldnt only for 277/480 correct
Old 04-19-2013, 07:57 AM   #25
Dana56's Avatar
It used to be common but not so mich anymore, sure its acceptable but most new installations call for an EGC to be pulled in conduits not just feeders. Not a blanket statement its the truth
Old 04-19-2013, 08:19 AM   #26
Dana56's Avatar
Feel like we are preparing to take a written test sheesh...
Old 04-19-2013, 04:07 PM   #27
Licensed electrician
Rewards Points: 1,864
That might be covered in the jobs specs, but it is not in the NEC. The NEC still considers metallic conduit a suitable ground.
Your experiences and preferences are above what is required.
Old 04-19-2013, 04:35 PM   #28
Semi-Pro Electro-Geek
Rewards Points: 2,990
On typical commercial jobs (office, retail, highrise) here in Phoenix, I never ran across a spec requiring EGCs for all circuits in conduit. It was only done where there was a specific reason for it, like where FMC was used for movement joints, or where there was a PVC underground section in a run.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 04-19-2013, 04:43 PM   #29
Dana56's Avatar
Really? Here in jersey its noted all the time to pull ground...had a friend grab a
Pipe that became energized hot hurt bad.. Thats why a ground shouldb pulledwhether required or not
Old 04-19-2013, 04:44 PM   #30
Dana56's Avatar
Not for all circuits by the way just one ground
2-2-4 SEU - Smaller Neutral? BRT Electrical 18 09-23-2012 09:25 PM
Replacing Light Fixture with No Ground Wire in Home panorama Electrical 42 09-14-2012 09:35 AM
Bare grounding pigtails? smata67 Electrical 2 05-27-2012 07:27 AM
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
