Grounding Panel In Outbuilding? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 05:07 PM   #1
Grounding panel in outbuilding?
I have an outbuilding we are planing to wire this year. We already have an underground wire coming from the house to the building. We were planning on using this again. (The building had previously been wired but with Rubber insulated woven sheathed non-mentallic sheathed cable) The wire coming out to the building was used in this previous electric system but had came out of the ground all the way up the wall and was connected to two insulators and was then spliced into the old nm. The underground wire looks like modern day underground cable but has no ground. We really don't want to have to dig it up as it appears to be in good shape. We realized we needed a sub panel out there to make it to code, but the service wire in ungrounded. Is there a way to ground this electrical service without replacing the service wire? The building is 19x16.
The first picture is of the previous service and were taken a few years ago before we gutted and renovated the building. And the underground wire we would like to use. We have ran the wire into the building through
Grounding panel in outbuilding?-dscn1833.jpg   Grounding panel in outbuilding?-dscn5294_2.jpg
awl98 is offline   Reply With Quote
Old 03-12-2013, 05:15 PM   #2
Rewards Points: 332
If there is conduit all the way to the house, you could just add a ground wire providing your don't hit overfill limits.
The proper way to wire a sub panel is to use 4 wires to the main panel and to add ground rods at the out building.
sgip2000 is offline   Reply With Quote
Old 03-12-2013, 05:22 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
what exactly do you have run out to that building for wires? And you don't need a subpanel to make it code....
Old 03-12-2013, 05:30 PM   #4
The wire is not in conduit all the way to the house, just coming out of the ground and going in. We plan to have 2 motion flood lights and one porch light outside, 2 ceiling lights in the main room, and 1 ceiling light in what was originally the bathroom, and outlets throughout. It was originally a cottage.
Old 03-12-2013, 05:31 PM   #5
E2 Electrician
I think you should start digging... going to have to install a new wire.
The Following User Says Thank You to stickboy1375 For This Useful Post:
joecaption (03-12-2013)
Old 03-12-2013, 05:36 PM   #6
I was reading that they grounding became code in 1962, and they didnt start using pvc outer sheathing until 1965. So I wonder why this wire has pvc sheathing and no ground?
Old 03-12-2013, 05:37 PM   #7
E2 Electrician
it exists....
Old 03-12-2013, 05:41 PM   #8
Electrician
Rewards Points: 150
Take a picture of the wires as they come out of the grey outer sheath. I want to see the colors and how many. Also I need the code on the sheath. It might say something like UF 12/2, UF B 14/2 with ground, etc.
Glennsparky is offline   Reply With Quote
Old 03-12-2013, 05:42 PM   #9
E2 Electrician
Op already stated it does not contain a grounding conductor, if this is true, he's **** out of luck.
Old 03-12-2013, 06:18 PM   #10
Heres a picture of the wire. I cant see any writing on the exterior sheathing because it has been painted over.
Grounding panel in outbuilding?-dscn8420.jpg   Grounding panel in outbuilding?-dscn8422.jpg
Old 03-12-2013, 06:19 PM   #11
E2 Electrician
You can't use it, so either go overhead, or start digging.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
awl98 (03-12-2013), jbfan (03-12-2013), Stubbie (03-12-2013)
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Main panel Bonding and grounding tulk Electrical 12 11-28-2012 10:19 PM
Grounding Panel at Barn EWW Electrical 4 12-23-2010 11:15 AM
Main grounding electrode wire to panel rovers1973 Electrical 4 03-18-2010 06:18 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
