Grounding Panel At Old Pipe - Electrical - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 05:24 PM   #1
I can fix that!
Rewards Points: 35
Grounding Panel at Old Pipe
I'm installing a new PEX water main and was considering leaving my old galvanized main stubbed into the basement and sticking 10-15' out into the yard so I can continue to use it as a ground. Does this make sense? I do not know yet if I have a second ground yet (new to me house and have not seen a grounding rod yet).
kuhlman is offline   Reply With Quote
Old 12-21-2011, 06:13 PM   #2
Mad Scientist
You might as well just drive an 8' ground rod instead, I dunno if the water pipe would still count as a grounding electrode once it was no longer a water pipe. And if you don't already have a ground rod, drive two 8' ground rods.
McSteve is offline   Reply With Quote
Old 12-21-2011, 06:14 PM   #3
Rewards Points: 6,652
When you called your permit office, what did they state about it being okay? The only problem that I see, is you are seeing it as a ground, but in reality, it is not. It no longer bonds the rest of the water system, so in theory it is nothing more than a ground rod.
Suggest you review your local codes regarding that you are now using PEX vs. Copper, as to how to bond the panel internally, along with ground rod outside.
Old 12-21-2011, 06:16 PM   #4
Mad Scientist
Ah, yeah, I forgot the water pipe bond. If your internal water pipes are still metal, you still need a bonding wire between your main panel and water pipes.
Gregzoll's answer is the best though, your local inspection office can tell you exactly what they like to see in your area.
Old 12-21-2011, 06:46 PM   #5
I can fix that!
Rewards Points: 35
Thanks for the responses! I will be changing all the interior plumbing to PEX as well. My thought was that the old galvanized pipe could be used as one of the grounding rods. But yes, I will talk to my local inspector before doing anything.
Old 12-22-2011, 07:21 AM   #6
Rewards Points: 1,506
The pipe does not have to carry water to be a grounding electrode; what does count is that at least 10 feet of it are buried and it is not a gas pipe.
If, due to plastic pipe, the rest of the plumbing system is not bonded to ground, then you need to add a #6 jumper to the original metal pipe exiting the house or to the fat ground wire (grounding electrode conductor) from there to the panel.
In some cities ground rods are needed even if you have a water pipe as a grounding electrode.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Wiring a sub panel to another sub panel Uncle Wayne Electrical 25 02-08-2011 09:50 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
