-   -   Grounding Panel at Barn (http://www.diychatroom.com/f18/grounding-panel-barn-90297/)
EWW 12-23-2010 06:25 AM
Ok, let me start by saying I have asked 3 different electricians and got 3 different answers.
I Am running electric to my barn, I have a 325 amp meter I have double lugs 1 branch is going to the house 200 amps and on the other I have run to my main disconnect to the barn. this is where I get confused, I have 3 wires from the Meter 2 hots and a common running to the disconnect from the meter, I have 4 wires rumnning to the barn from the disconnet do I bond the ground and common at the diconnect? In other words connect the green wire (that is running to the barn) to the disconnect box ground and install the bonding screw? Then at the panel in the barn connect that green wire to a separate ground bar that connects to a earth ground rod? My panel at the barn has 2 bars that are connected, so I bleieve I have to buy a grounding bar kit and intall for the Earth grond and ground wire running from disconnect. And I do not bond them at that panel. thanks for any help, I am just a hands on type person and have received conflicting information that is confuseing me. More info this is 100 amps and about 80' from the meter to the barn.
joed 12-23-2010 07:53 AM
Bond the ground and neutral at the first disconnect. I think you need ground rods here.
Do not bond them at the barn. Install ground rods at the barn.
jerzeedivr 12-23-2010 10:25 AM
2nd box
When power comes into first panel N (White) and G (green) land on the ground block, on the 2nd. panel the N block has to be isolated from touching the panel. I believe it is so electricity can't flow in a circle so you will need an isolated N block with insulator under it and a ground block to the box. N and G have to be seperate in 2nd panel. I'm not sure if you need a ground rod at the barn, I don't think so.
EWW 12-23-2010 11:12 AM
I have 2 hots and a Common coming from the Meter to the disconnect, and 2 hots, a common, and a ground from the Disconnect to the panel in the barn. Where do you terminate the Green Ground at that goes to the Panel in the Barn and where does it terminate in the Disconnect? I am confused because some have told me that I do not need the green ground between the disconnect and the barn. I understand that I should not bond the ground and common at he barn but would that Green ground wire that runs between the barn and disconnect be bonded at the disconnect and then a seperate ground at the barn panel? Sorry I am just confused because of the differnet responses I have received form electricians locally.
joed 12-23-2010 11:15 AM
Add a gropund bar to the p anel inthe barn. Terminate your ground on the new bar. DO NOT use the green bonding screw to bond the neutral to the panel.
