Grounding Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 01:20 PM   #1
Grounding outlet
Surge protector indicates the outlet is not grounded. How do I ground the outlet or is it the breaker box that needs grounding?
ALWavada is offline   Reply With Quote
Old 05-28-2012, 01:31 PM   #2
Licensed electrician
Rewards Points: 1,036
This would depend on the wiring method to the receptacle. This has nothing to do with the panel grounding.
It may be just as easy to install a new grounded circuit.
Old 05-28-2012, 02:06 PM   #3
Rewards Points: 6,652
First question, are you renting or do you own this place?
Old 05-28-2012, 03:38 PM   #4
joed's Avatar
Rewards Points: 11,598
Either the ground broken somewhere and needs to be fixed or the more likely option is that someone replaced a two prong receptacle with a three prong receptacle and did not connect the ground because it was not there.
Grounding an End of the Run Outlet for a Smoke Detector WoodmanFL Electrical 5 12-17-2011 03:01 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Grounding outlet to armored cable - fine? voltage2 Electrical 14 02-19-2008 12:03 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
