I am new here and need some advice.
I have read quite some threads regarding what I want to do but none give a pretty stragith forward answer to what I want to do.
Just as the thread title, I want to ground an outlet, the idea is to put a 3-prong outlet where the 2 prong one is and run a wire from the ground connection on the new outlet to a grounding rod.
Some aditional info you'll need to properly advice me on this, I cannot properly rewire the house to add the ground, it's all a 2-prong connection scheme, the house is made of brick walls so it would be too expensive to try to do add the ground connection; All outlets are encased in metal casings but I doubt any of them are grounded (how can I test this??) so to protect what gives me to eat (my computer) this is the only idea I could come up with that made a little sense.
Excuse the lack of technical language, I know nothing of it.
Also, as far as electrical codes goes I have no idea what we use here (Honduras, Latin america) but I am pretty sure it would be something along the lines of what the US uses.
Thanks in advance for your help
