Old 11-09-2010, 09:30 PM   #1
grounding an old bathroom
my house is old, and there is no ground to the 2nd floor. My 100 break panel is ground to the main water pipe,and the 1st floor and the basement are grounded.My question is: Can i connect a ground wire from cold water pipe to the outlet in bathroom in the 2nd floor ? It is only 1m of wire.Thanks
gefeiora is offline   Reply With Quote
Old 11-09-2010, 09:41 PM   #2
" Euro " electrician
frenchelectrican's Avatar
In USA no it is not allowed but Canada I am not sure if they still allowed or not so hang on tight one of the Canadian electrician will comfirm this part.
Merci.
Marc
Old 11-09-2010, 09:41 PM   #3
my house is old and the 2nd floor has no grounding.I have a 100 amp panel grounded to the main water pipe, and the basement a 1st. floor are grounded. My question is.on the 2nd floor bathroom can i connect a ground wire(1m) from the cold water pipe to the outlet?Thanks
Old 11-10-2010, 12:08 AM   #4
thanks,Frenchelectrican
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Sub Panel Grounding bar bmancanfly Electrical 12 05-24-2009 03:07 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 05:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
