Old 12-06-2005, 02:58 PM   #1
Question
Grounding a non-grounded receptacle
I have recently bought an older 60's home which has no grounded receptacles. A friend told me I could replace the old 2-wire outlets with grounded ones and just jump a piece of copper wire from the ground screw to the neutral on the new outlet and it would be grounded. I think I'm repeating his instructions right. Is this true, or should I replace the old outlet with a GFCI until I can do some rewiring? Is there any other way to do a pigtail and ground a non grounded outlet? :confused:
lee73401 is offline   Reply With Quote
Old 12-06-2005, 03:16 PM   #2
Electrical Contractor
Your friend is wrong!!! I would go with the GFCI idea until you can rewire. It may be possible that you have a ground at the outlet, but I woould get an electrician to check it before assuming anything.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 12-06-2005, 06:47 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Friends who have NO clue about electric should not be giving electrical advice.
Old 12-07-2005, 07:31 AM   #4
If you have bx with metal boxes you will have to test the metal box to see if it is grounded.If it is just buy some grounding pigtails(green wire with green ground screw). Attach the screw to the back of the metal box and the other end to the plug.
donkey is offline   Reply With Quote
Old 12-09-2005, 03:25 PM   #5
2nd half
Ditto on the Donkeys advise!
jmic is offline   Reply With Quote
Post mounted electrical receptacle ¯¯NI¯l¯RO¯¯ Electrical 13 04-19-2010 03:20 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
Split Receptacle on 3-Way Circuit NPS Electrical 6 11-03-2005 10:28 AM
20A or 15A receptacle ejlog Electrical 3 02-21-2005 07:29 PM
