Grounding A Non-grounded Metal Blower - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2007, 03:51 PM   #1
Grounding a non-grounded metal blower
I have a blower (metal housing) that works fine except the 2 wire power cord has been damaged. I'd like to replace the old power cord with a new grounded power cord. The blower motor is currently grounded to the metal housing of the blower. Can I just connect the ground wire on the new power cord to the ground wire that is currently connected to the motor and metal housing? I will be touching the metal housing while the blower is being used.
o2barockstar is offline   Reply With Quote
Old 10-22-2007, 08:53 PM   #2
Sounds like the neutral was connected to the metal housing before, which does not sound all that safe. Your Idea sounds better.
Ground from house to metal frame of blower.
neutral from house to neutral from blower
hot from house to hot from blower via the blower switch.
Master Electrician
jwhite is offline   Reply With Quote
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 02:59 AM
grounding pole building sheet metal? borderbuster Electrical 2 07-08-2007 02:11 AM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
