Grounding New 200a Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 01:39 PM   #1
grounding new 200a panel
I am installing a new semi flush 200a meter/breaker panel. the neutral meter lug is bonded to the panel, and comes into the breaker side to a common bus. There is no ground bus bar
Q- do i need to install a separate ground bus for my circuit ground(s) and ground rod, and if so, do they need to be bonded together? or can i just use the common bus for all grounds and commons if there is adequate space?
socalsteve72 is offline   Reply With Quote
Old 03-10-2012, 01:42 PM   #2
Licensed electrician
Rewards Points: 1,020
Since this is a service panel you can land the neutral and grounds on the same buss. The bond screw will need to be installed.
Old 03-10-2012, 01:49 PM   #3
bond screw?
Old 03-10-2012, 01:56 PM   #4
It should come with the panel. It connects the enclosure to the buss.
Old 03-10-2012, 02:07 PM   #5
the buss came already mounted & bonded to the enclosure so i should be good to go-- thanks!
2/2/2 AL into 200A panel njwoodworker Electrical 11 07-25-2011 02:00 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 09:00 PM
Service Panel Replacement and 200A upgrade mark_anderson_u Electrical 2 09-10-2010 07:43 AM
sub panel grounding jprince Electrical 2 05-04-2009 07:15 PM
