Grounding And Neutral Wire Too Large For Neutral Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 03-05-2011, 03:25 PM   #1
grounding and neutral wire too large for neutral bar
what are my opions if my neutraul bar does not have a hole large enough for my # 1 neutral wire and # 2 ground wire running from my main box to sub 100amp sub panel?
cpainter2 is offline   Reply With Quote
Old 03-05-2011, 04:21 PM   #2
Licensed electrician
Rewards Points: 1,758
There are adapter lugs available for most panels.
cpainter2 (03-05-2011)
Old 03-05-2011, 07:19 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
As Jim said they make terminal lugs for the panel neutral bar and are along these lines or similar
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-05-2011, 08:15 PM   #4
what i just got from home depot. thanks
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
